[GRASS-user] GRASS_VERBOSE=-1
    Laurent C.
    lrntct at gmail.com
    Sat Aug 13 07:42:26 PDT 2016
Hello,
Then pass quiet=true to run_command()
Laurent
El ago. 13, 2016 2:39, "Micha Silver" <micha at arava.co.il> escribió:
> ------ Original Message ------ Subject: Re: [GRASS-user] GRASS_VERBOSE=-1
> Date: Fri, 12 Aug 2016 18:21:55 -0500 To: Micha Silver, Grass User List
> From: Laurent C.
>> Hello,
>> One solution is to set the environment variable like this:
>> os.environ['GRASS_VERBOSE'] = '3'
> What I want to do is surpress the warning messages altogether.
> Setting with:
> os.environ['GRASS_VERBOSE'] = '-1'
> doesn't seem to do anything.
> the other is to pass the verbosity as an argument to
>> run_command(verbose=True)
>> Cheers,
>> Laurent
>> 2016-08-12 9:56 GMT-05:00 Micha Silver <micha at arava.co.il>:
>>> How do I use the VERBOSE=-1 option in a python script?
>>> I am importing lists of rasters that do not have CRS info (grib2
>>> format), so
>>> I use the '-o' option to override CRS check. But the screen gets filled
>>> with:
>>> WARNING: Datum <unknown> not recognised by GRASS and no parameters found
>>> WARNING: Over-riding projection check
>>> and I miss the messages that I want to see.
>>> Thanks
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160813/ccd3b8ef/attachment.html>
