[GRASS-user] GRASS_VERBOSE=-1
Micha Silver micha at arava.co.il
Sat Aug 13 10:24:31 PDT 2016
Hi Laurent
The quiet flag, it seems, doesn't affect warnings. They get printed to
stdout even with quiet=True.
------ Original Message ------ Subject: Re: [GRASS-user]
GRASS_VERBOSE=-1 Date: Sat, 13 Aug 2016 09:42:26 -0500 To: Micha Silver,
Grass User List From: Laurent C.
> Hello,
> Then pass quiet=true to run_command()
> Laurent
> El ago. 13, 2016 2:39, "Micha Silver" <micha at arava.co.il
>     GRASS_VERBOSE=-1 Date: Fri, 12 Aug 2016 18:21:55 -0500 To: Micha
>     Silver, Grass User List From: Laurent C.
>         Hello,
>         One solution is to set the environment variable like this:
>         os.environ['GRASS_VERBOSE'] = '3'
>     What I want to do is surpress the warning messages altogether.
>     Setting with:
>     os.environ['GRASS_VERBOSE'] = '-1'
>     doesn't seem to do anything.
>         the other is to pass the verbosity as an argument to
>         run_command(verbose=True)
>         Cheers,
>         Laurent
>         2016-08-12 9:56 GMT-05:00 Micha Silver <micha at arava.co.il
>         <mailto:micha at arava.co.il>>:
>             How do I use the VERBOSE=-1 option in a python script?
>             I am importing lists of rasters that do not have CRS info
>             (grib2 format), so
>             I use the '-o' option to override CRS check. But the
>             screen gets filled
>             with:
>             WARNING: Datum <unknown> not recognised by GRASS and no
>             parameters found
>             WARNING: Over-riding projection check
>             and I miss the messages that I want to see.
>             Thanks
>             _______________________________________________
>             grass-user mailing list
>             grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/grass-user
>             <http://lists.osgeo.org/mailman/listinfo/grass-user>
