[GRASS-user] GRASS at the 12th International Conference on Hydroinformatics
Laurent C.
lrntct at gmail.com
Tue Aug 16 12:43:34 PDT 2016
2016-08-16 13:30 GMT-05:00 Vaclav Petras <wenzeslaus at gmail.com>:
> On Sat, Aug 13, 2016 at 1:09 PM, Laurent C. <lrntct at gmail.com> wrote:
>> I've tried but never manage to make it work. See:
>> https://lists.osgeo.org/pipermail/grass-dev/2016-March/079481.html
>> https://trac.osgeo.org/grass/ticket/2480
>> https://trac.osgeo.org/grass/ticket/2968
>> So I finally decided to make it a Python package and drop g.parser for
>> argparse.
> Hi Laurent,
> you can actually still use GRASS parser even if you are not using
> g.extension. The only condition for GRASS parser to work is that you script
> is running inside GRASS session. You can even use both GRASS parser and your
> current mechanism if you have some way of distinguishing the command lines
> from each other and than calling the proper set of functions.
> Vaclav
Hi Vaclav,
I know. But since the module was not compiling, the GUI was not
working, so the main advantage of using g.parser over argparse was
gone.
Laurent
