[GRASS-user] Working with LiDAR data
Rich Shepard rshepard at appl-ecosys.com
Mon Aug 29 15:51:32 PDT 2016
On Mon, 29 Aug 2016, Anna Petrášová wrote:
> If you would get the original las files, you could have more control
> over the processing if that's desired.
Hi, Anna,
   I don't know if the original las files are available; I'll ask the agency
for them (and I have a las compression library that reduces storage volume
for the .las files.)
   As I'm learning about LiDAR data I've no idea what I need in terms of
processing. These data are quite different from the 10m DEMs I've used for
years.
> for contours use r.contours and for flow accumulation use r.watershed, but
> depends what exactly you want do. Some of these topics are covered for
> example here:
> http://ncsu-geoforall-lab.github.io/geospatial-modeling-course/grass/
   OK, then, nothing significant has changed external to the modules.
Thanks very much,
Rich
