[GRASS-user] Grass: Finding depression from contour
Faisal Kabir faisal.kabir at gmail.com
Sat Dec 10 20:01:02 PST 2016
I've labeled contour (DEM) map using d.vect. Now I would like to find the
depression [contour with low elev value are inside the contour of higher
elev] automatically. I can view it in the Map display window which is
tedious as I've to zoom in and out for several times.
Is there any method available in GRASS?
Thanks in advance!
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161210/aef64735/attachment.html>
