[GRASS-user] Organizing locations and mapsets on NFS for teams
Anna Petrášová kratochanna at gmail.com
Fri Feb 5 11:08:29 PST 2016
On Fri, Feb 5, 2016 at 3:55 AM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
> Hi again,
> Two related things:
> I just started collecting GRASS data which has been floating around in
> different GRASS DBs in my institute into one, central DB.
> In that context I am implementing a kind of naming convention (like the
> one sketched below) in order to make the data order systematically.
> My two questions are now:
> 1) Would it be much work to implement a filter in the Location and Mapset
> selection window, which would reduce the list to "mapsets owned by me"
> (e.g. in a tickbox), as these are the only ones I technically can use for
> working anyway?
> 2) Is it possible in the WX GUI to allow the user to change the
> distribution of horizontal space used for the "mapset box" and the
> "locations box", meaning, that I can make the mapset box wider myself if I
> have longer mapset names?
> Would you consider it relevant enough for an enhancement ticket?
yes, please create a ticket, at least the 2) should be easy.
Anna
> Kind regards,
> Stefan
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org [mailto:
> grass-user-bounces at lists.osgeo.org] On Behalf Of Blumentrath, Stefan
> Sent: 4. oktober 2015 15:23
> To: Markus Neteler <neteler at osgeo.org>
> Cc: grass-user grass-user (grass-user at lists.osgeo.org) <
> grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] Organizing locations and mapsets on NFS for teams
> Hi Markus,
> Thanks for your reply.
> Yes, I was referring to the "Using GRASS GIS locations in a
> network"/"Student machine(s)" section. I overlooked the "NFS read-only
> reason" for this solution...
> Do you (or anyone else) have a smart solution for keeping your locations
> on NFS tidy? Are you and your colleagues only very disciplined or do you
> have a kind of data care taker who cleans up the GRASS DB regularly and
> maybe archives expired projects?
> Do you use specific naming conventions (esp. for mapsets but maybe also
> maps)? We copied the convention used on the wiki-page to name locations by
> CRS, but I am less sure what to do when it comes to mapsets... Here, I was
> considering using prefixes like "G_" for all mapsets of general interest
> (probably "GT_" for TGIS-mapsets) followed by a thematic name / keyword,
> "P_" followed by project name for project mapsets, and "U_" followed by
> user name for user mapsets...  So at least these conceptually different
> mapset types group / order logicaly...
> And how do you maintain the PERMANENT mapset(s) on NFS. Does only the
> creator of the location use / modify it? Are there any solutions for doing
> that in a collaborative approach (which might be used for other mapsets
> too)? I mean in terms of access rights...
> Do you use a metadata repository to make it transparent for everybody what
> data is in what mapset?
> Sorry for the bunch of questions. Using GRASS already helps a lot to have
> and keep the (growing amounts of) data well structured, but a description
> of recommended practices or field-proven solution might help users to get
> even more out of it...
> Kind regards
> Stefan
> From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf
> Of Markus Neteler
> Sent: 4. oktober 2015 09:01
> To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
> On Thu, Oct 1, 2015 at 12:19 PM, Blumentrath, Stefan <
> > The solution described here:
> > https://grasswiki.osgeo.org/wiki/Location_and_Mapsets with common
> > GRASS DB on NFS linked into users home directory is somewhat sexy in
> > order to keep the “user mapsets” out of the common GRASS GIS DB. The
> > drawback however is, that users explicitly have to switch between the
> > two GRASS DBs if they want to share data on NFS, if I understood the
> consequences correctly.
> Are you sure about this? Do you refer to the section "Student machine(s)"?
> In my group, we simply have all in /grassdata/ which is on NFS (actually
> with a big BeeGFS device behind).
> Works nicely.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160205/d646e6bf/attachment-0001.html>
