[GRASS-user] i.landsat.toar not working with band 6 of Landsat 7
anna zanchetta
ciupava at gmail.com
Sun Feb 7 14:16:56 PST 2016
yes, i was referring to that.
i think the problem is connected to the fact that i.landsat.toar works
recursively on all bands
which is what makes this command comfortable but in the same time it
doesn't allow to calculate the TOAR for a specific band, in case one would
like to do so
thanks,
Anna
On Mon, Feb 8, 2016 at 12:00 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sun, Feb 7, 2016 at 9:48 PM, anna zanchetta <ciupava at gmail.com> wrote:
> > hi grass users,
> > i found a problem when running i.landsat.toar with Landsat 7,
> > then i've eventually found in gis-stackexchange a "tricky" way to solve
> it:
> http://gis.stackexchange.com/questions/133053/i-landsat-toar-doesnt-work-with-band-6-of-landsat-7-in-grass-7
> > i found it a bit clunky and thought to let you know in case someone
> wants to
> > deal with this issue...
> So, you refer to "renaming LE70010752014040CUB00_B6_VCID_1 to
> LE70010752014040CUB00_B61 do the trick." ?
> Indeed suboptimal. But I guess that pattern matching would make the
> interface more complicated.
> Maybe other developers have an idea?
> Best
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160208/7d5350b6/attachment.html>
