[GRASS-user] i.landsat.toar not working with band 6 of Landsat 7
Kozlova Maria kclo at yandex.ru
Sun Feb 7 23:25:24 PST 2016
Dear Anna,
We solved such problems by writing python script for automated rename of files corresponded to ETM+ thermal bands before processing in Grass as we often have to work with many images.
in the case of single images it is not a problem to rename it to format LE........B61 and B62. Then after ETM+ data import to GRASS, i.landsat.toar work properly.
Best regards,
Maria V. Kozlova
  Information System Lab. (ISysLab)
  State Oceanographic Institute,
  Kropotkinsky per., 6,
  MOSCOW, 119034,
  RUSSIA
  tel.    +7 499 246 6448
  fax.    +7 499 246 7288
  mailto:  kclo at yandex.ru
08.02.2016, 01:17, "anna zanchetta" <ciupava at gmail.com>:
> yes, i was referring to that.
> i think the problem is connected to the fact that i.landsat.toar works recursively on all bands
> which is what makes this command comfortable but in the same time it doesn't allow to calculate the TOAR for a specific band, in case one would like to do so
> thanks,
> Anna
> On Mon, Feb 8, 2016 at 12:00 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sun, Feb 7, 2016 at 9:48 PM, anna zanchetta <ciupava at gmail.com> wrote:
>>> hi grass users,
>>> i found a problem when running i.landsat.toar with Landsat 7,
>>> then i've eventually found in gis-stackexchange a "tricky" way to solve it:
>>> http://gis.stackexchange.com/questions/133053/i-landsat-toar-doesnt-work-with-band-6-of-landsat-7-in-grass-7
>>> i found it a bit clunky and thought to let you know in case someone wants to
>>> deal with this issue...
>> So, you refer to "renaming LE70010752014040CUB00_B6_VCID_1 to
>> LE70010752014040CUB00_B61 do the trick." ?
>> Indeed suboptimal. But I guess that pattern matching would make the
>> interface more complicated.
>> Maybe other developers have an idea?
>> Best
>> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
