[GRASS-user] i.spec.sam error
Jaya Krishnan jayaakrish at gmail.com
Sat Feb 13 11:34:27 PST 2016
Hi Markus and Moritz,
Thanks for replying.
I am working on Windows 7 and using GRASS 7.0.3 on OSGeo4W. I installed
i.spec.sam using g.extension, and tried to run it from the command console,
but get the error
* 'i.spec.sam' is not recognized as an internal or external
command,operable program or batch file.*
Thank you,
Jaya
​LinkedIn: ​
https://ca.linkedin.com/in/jayaakrish
On 13 February 2016 at 04:02, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 13/02/16 03:14, Jaya Krishnan wrote:
>> Hi,
>> I am trying to use the addon i.spec.sam on GRASS 7.0.3, but am getting
>> an error "'i.spec.sam' is not recognized as an internal or external
>> command". Any help is appreciated.
> i.spec.sam is an addon, so you have to install it first with:
> g.extension i.spec.sam
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160213/7df68337/attachment.html>
