[GRASS-user] i.spec.sam error
Jaya Krishnan jayaakrish at gmail.com
Mon Feb 15 11:59:27 PST 2016
Hi Vero,
Yes, I've installed the same versions from OSGeo4w, pretty recently.
Neither R nor RStudio works in my case.
Thanks,
Jaya
​ <https://ca.linkedin.com/in/jayaakrish>
On 15 February 2016 at 06:05, Veronica Andreo <veroandreo at gmail.com> wrote:
> Hello Jaya
> [cc Helmut]
> In grass 7.0.3 and grass 7.1 installed from OSGeo4w (updated just now), if
> in comand line i write rstudio only... no path, no extension, it works as
> expected... but not if I write only R... i remember both options worked
> before (
> http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-td5235108.html#a5236435).
> Maybe some further changes altered that.
> Cheers,
> Vero
> 2016-02-14 18:14 GMT-03:00 Jaya Krishnan <jayaakrish at gmail.com>:
>> Thanks Sajid, but that didn't work either.
>> Best,
>> Jaya
>> On 14 February 2016 at 02:56, Sajid Pareeth <spareeth at gmail.com> wrote:
>>> Hi Jaya
>>>> Sorry to bother you again. But I was thinking of using Spectral Angle
>>>> Mapper in RStudio's RSToolbox package as an alternative. So I followed the
>>>> steps at the link
>>>> https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7#Using_RStudio_in_a_GRASS_GIS_session
>>>> but am unable to run RStudio at the GRASS command prompt. The error is
>>>> again * 'rstudio' is not recognized as an internal or external
>>>> command,operable program or batch file *(attaching error below).
>>> Please try by entering entire path in the GRASS session instead of
>>> "rstudio.exe".
>>>> C:\Program Files\RStudio\bin\rstudio.exe
>>> Regards
>>> Sajid Pareeth
>>> https://it.linkedin.com/in/spareeth
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160215/b07e1a45/attachment-0001.html>
