[GRASS-user] i.spec.sam error
Helmut Kudrnovsky
hellik at web.de
Mon Feb 15 06:12:32 PST 2016
Veronica Andreo wrote
> Hello Jaya
> [cc Helmut]
> In grass 7.0.3 and grass 7.1 installed from OSGeo4w (updated just now), if
> in comand line i write rstudio only... no path, no extension, it works as
> expected... but not if I write only R... i remember both options worked
> before (
> http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-td5235108.html#a5236435).
> Maybe some further changes altered that.
> Cheers,
> Vero
> 2016-02-14 18:14 GMT-03:00 Jaya Krishnan <
> jayaakrish@
>> Thanks Sajid, but that didn't work either.
>> Best,
>> Jaya
>> On 14 February 2016 at 02:56, Sajid Pareeth <
> spareeth@
> > wrote:
>>> Hi Jaya
>>>> Sorry to bother you again. But I was thinking of using Spectral Angle
>>>> Mapper in RStudio's RSToolbox package as an alternative. So I followed
>>>> the
>>>> steps at the link
>>>> https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7#Using_RStudio_in_a_GRASS_GIS_session
>>>> but am unable to run RStudio at the GRASS command prompt. The error is
>>>> again * 'rstudio' is not recognized as an internal or external
>>>> command,operable program or batch file *(attaching error below).
>>> Please try by entering entire path in the GRASS session instead of
>>> "rstudio.exe".
>>>> C:\Program Files\RStudio\bin\rstudio.exe
>>> Regards
>>> Sajid Pareeth
>>> https://it.linkedin.com/in/spareeth
>> grass-user mailing list
> grass-user at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Please see https://trac.osgeo.org/osgeo4w/ticket/413
Unfortunately I haven't found time yet to implement the simple R-winGrass
coupling into Osgeo4w which is already working in standalone winGRASS.
As Veronica mentioned, rstudio should work in the newest Osgeo4w and
standalone winGRASS ; R and rstudio should work only in standalone winGRASS.
I hope to find time in the next weeks.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-spec-sam-error-tp5250345p5250557.html
Sent from the Grass - Users mailing list archive at Nabble.com.
