[GRASS-user] i.spec.sam error
Veronica Andreo
veroandreo at gmail.com
Mon Feb 15 12:08:18 PST 2016
Hi Jaya
and have you tried installing the grass-win standalone installer from here
[0]? Helmut says both rstudio and R work there. I removed them from my
mum's windows pc, but I remember I tested and it worked there. Maybe worth
a try :)
Cheers,
Vero
[0] https://grass.osgeo.org/download/software/
2016-02-15 16:59 GMT-03:00 Jaya Krishnan <jayaakrish at gmail.com>:
> Hi Vero,
> Yes, I've installed the same versions from OSGeo4w, pretty recently.
> Neither R nor RStudio works in my case.
> Thanks,
> Jaya
> <https://ca.linkedin.com/in/jayaakrish>
> On 15 February 2016 at 06:05, Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hello Jaya
>> [cc Helmut]
>> In grass 7.0.3 and grass 7.1 installed from OSGeo4w (updated just now),
>> if in comand line i write rstudio only... no path, no extension, it works
>> as expected... but not if I write only R... i remember both options worked
>> before (
>> http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-td5235108.html#a5236435).
>> Maybe some further changes altered that.
>> Cheers,
>> Vero
>> 2016-02-14 18:14 GMT-03:00 Jaya Krishnan <jayaakrish at gmail.com>:
>>> Thanks Sajid, but that didn't work either.
>>> Best,
>>> Jaya
>>> On 14 February 2016 at 02:56, Sajid Pareeth <spareeth at gmail.com> wrote:
>>>> Hi Jaya
>>>>> Sorry to bother you again. But I was thinking of using Spectral Angle
>>>>> Mapper in RStudio's RSToolbox package as an alternative. So I followed the
>>>>> steps at the link
>>>>> https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7#Using_RStudio_in_a_GRASS_GIS_session
>>>>> but am unable to run RStudio at the GRASS command prompt. The error is
>>>>> again * 'rstudio' is not recognized as an internal or external
>>>>> command,operable program or batch file *(attaching error below).
>>>> Please try by entering entire path in the GRASS session instead of
>>>> "rstudio.exe".
>>>>> C:\Program Files\RStudio\bin\rstudio.exe
>>>> Regards
>>>> Sajid Pareeth
>>>> https://it.linkedin.com/in/spareeth
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160215/874ba1b0/attachment.html>
