[GRASS-user] i.spec.sam error
Jaya Krishnan jayaakrish at gmail.com
Mon Feb 15 12:28:15 PST 2016
Thanks a ton Vero! I installed the standalone version and RStudio works :-)
Cheers
Jaya
​ <https://ca.linkedin.com/in/jayaakrish>
On 15 February 2016 at 12:08, Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi Jaya
> and have you tried installing the grass-win standalone installer from here
> [0]? Helmut says both rstudio and R work there. I removed them from my
> mum's windows pc, but I remember I tested and it worked there. Maybe worth
> a try :)
> Cheers,
> Vero
> [0] https://grass.osgeo.org/download/software/
> 2016-02-15 16:59 GMT-03:00 Jaya Krishnan <jayaakrish at gmail.com>:
>> Hi Vero,
>> Yes, I've installed the same versions from OSGeo4w, pretty recently.
>> Neither R nor RStudio works in my case.
>> Thanks,
>> Jaya
>> On 15 February 2016 at 06:05, Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>>> Hello Jaya
>>> [cc Helmut]
>>> In grass 7.0.3 and grass 7.1 installed from OSGeo4w (updated just now),
>>> if in comand line i write rstudio only... no path, no extension, it works
>>> as expected... but not if I write only R... i remember both options worked
>>> before (
>>> http://osgeo-org.1560.x6.nabble.com/R-and-RStudio-in-winGRASS-testing-welcome-td5235108.html#a5236435).
>>> Maybe some further changes altered that.
>>> Cheers,
>>> Vero
>>> 2016-02-14 18:14 GMT-03:00 Jaya Krishnan <jayaakrish at gmail.com>:
>>>> Thanks Sajid, but that didn't work either.
>>>> Best,
>>>> Jaya
>>>> On 14 February 2016 at 02:56, Sajid Pareeth <spareeth at gmail.com> wrote:
>>>>> Hi Jaya
>>>>>> Sorry to bother you again. But I was thinking of using Spectral Angle
>>>>>> Mapper in RStudio's RSToolbox package as an alternative. So I followed the
>>>>>> steps at the link
>>>>>> https://grasswiki.osgeo.org/wiki/R_statistics/rgrass7#Using_RStudio_in_a_GRASS_GIS_session
>>>>>> but am unable to run RStudio at the GRASS command prompt. The error is
>>>>>> again * 'rstudio' is not recognized as an internal or external
>>>>>> command,operable program or batch file *(attaching error below).
>>>>> Please try by entering entire path in the GRASS session instead of
>>>>> "rstudio.exe".
>>>>>> C:\Program Files\RStudio\bin\rstudio.exe
>>>>> Regards
>>>>> Sajid Pareeth
>>>>> https://it.linkedin.com/in/spareeth
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160215/ba4e0499/attachment-0001.html>
