[GRASS-user] v.net.iso GUI
Štěpán Turek
stepan.turek at seznam.cz
Sat Feb 20 04:27:31 PST 2016
Hi Aldo,
you can define the distances on the Points page of the GUI.
On the page, there is a column "Iso lines:". The column is shown only if v.
net.iso is selected. See the attachment.
Best
Stepan
Date: 2016-02-20 12:44 GMT+01:00
Subject: [GRASS-user] v.net.iso GUI
To: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
I’m using v.net.iso through the GUI (7.0.3) and I’m not able to insert
the distance (or cost) values. It seems that the module uses by
default three distances of 1000 m each. For example, by using a copy
of roads (Spearfish) named roads_copia (Fig.1), and defining two
points in the area (Fig.2) the results are as reported in Fig.3 (three
distances of 1000, 2000, 3000m from each point). Is there a way in the
panel to define the distances (in other words to insert the equivalent
of the parameter costs in Command line mode)?
Thanks in advance.
Aldo Clerici
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa"
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160220/9ce1ce93/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160220/9ce1ce93/attachment-0001.png>
