[GRASS-user] r.unpack fails
Rengifo Ortega rengifoo at yahoo.de
Thu Feb 25 01:13:18 PST 2016
Dear grass community ,I am trying to unpack a set of files, but I get the error. I am using  grass gis 7.0.3 on a windows enterprise. The file  I am trying to open is around 84gb  as packed file.I do not know if am making something wrong.here I describe  what I did.-I  created  a location with a generic coordinate system-then I try to open the file(s) using r.unpack. After 92 min I got the error below.
Any help will be appreciated
r.unpack input=J:\dataset\dem_10m_xxx_float_accum.pack                  Traceback (most recent call last):  File"C:\OSGEO4~1\apps\grass\grass-7.0.3/scripts/r.unpack.py",line 164, in <module>    sys.exit(main())  File"C:\OSGEO4~1\apps\grass\grass-7.0.3/scripts/r.unpack.py",line 120, in main    proj=True):  File "C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\script\core.py", line 897, in compare_key_value_text_files    checkunits=units)  File "C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\script\core.py", line 822, in _text_to_key_value_dict    text = open(filename, "r").readlines()IOError: [Errno 2] No such file or directory: 'E:\\0WORKFLOW_AND_PROJECTS\\hydroScandinavia\\PERMANENT\\..\\PERMANENT\\PROJ_INFO'(Wed Feb 24 22:32:35 2016) Command finished (92 min 51 sec)
Mvh
Rengifo Ortega
Overingeniør
Seksjon for geoinformasjon
Hydrologisk avdelingen
Norges vassdrags- og energidirektoratet (NVE)
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160225/473a633f/attachment.html>
