[GRASS-user] r.unpack fails
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Feb 25 01:36:37 PST 2016
Not sure if the the CRS can be an issue…
But the data is from a Location in EPSG:25833. Maybe you have to import into a location with the same CRS?
Cheers
Stefan
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Rengifo Ortega
Sent: 25. februar 2016 10:13
To: GRASS User List <grass-user at lists.osgeo.org>
Subject: [GRASS-user] r.unpack fails
Dear grass community ,
I am trying to unpack a set of files, but I get the error. I am using grass gis 7.0.3 on a windows enterprise. The file I am trying to open is around 84gb as packed file.
I do not know if am making something wrong.
here I describe what I did.
-I created a location with a generic coordinate system
-then I try to open the file(s) using r.unpack. After 92 min I got the error below.
Any help will be appreciated
r.unpack input=J:\dataset\dem_10m_xxx_float_accum.pack
File
"C:\OSGEO4~1\apps\grass\grass-7.0.3/scripts/r.unpack.py",
line 164, in <module>
sys.exit(main())
File
line 120, in main
proj=True):
File "C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\
script\core.py", line 897, in compare_key_value_text_files
checkunits=units)
script\core.py", line 822, in _text_to_key_value_dict
text = open(filename, "r").readlines()
IOError: [Errno 2] No such file or directory: 'E:\\0WORKFLOW
_AND_PROJECTS\\hydroScandinavia\\PERMANENT\\..\\PERMANENT\\P
ROJ_INFO'
(Wed Feb 24 22:32:35 2016) Command finished (92 min 51 sec)
Mvh
Rengifo Ortega
Overingeniør
Seksjon for geoinformasjon
Hydrologisk avdelingen
Norges vassdrags- og energidirektoratet (NVE)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160225/2655c794/attachment-0001.html>
