[GRASS-user] 3d boreholes with v.extrude on different plane
Anna Petrášová
kratochanna at gmail.com
Sun Feb 28 18:21:04 PST 2016
Could you send me the data using v.pack?
On Sun, Feb 28, 2016 at 7:16 PM, Alec Ventura <alecventura at hotmail.com>
wrote:
> | Mapset: Map
> | Location: Tests
> | Database: C:\Users\Vulcan\Documents\grassdata
> | Title:
> | Map scale: 1:1
> | Name of creator: Vulcan
> | Organization:
> | Source date: Sun Feb 28 19:14:22 2016
> | Timestamp (first layer): none
> | Map format: native
> | Type of map: vector (level: 2)
> | Number of points: 0 Number of centroids: 0
> | Number of lines: 0 Number of boundaries: 0
> | Number of areas: 0 Number of islands: 0
> | Number of faces: 25 Number of kernels: 1
> | Number of volumes: 0 Number of holes: 0
> | Map is 3D: Yes
> | Number of dblinks: 1
> | Projection: UTM (zone invalid)
> | N: 7074915.22090919 S: 7072919.88337081
> | E: 383218.654546 W: 381227.96859996
> | B: 100 T: 2000
> | Digitization threshold: 0
> | Comment:
> | Generated by v.extrude from vector map <tmp at Map>
> and
> | Mapset: Map
> | Location: Tests
> | Title:
> | Map scale: 1:1
> | Organization:
> | Source date: Sun Feb 28 19:15:15 2016
> | Map format: native
> | Map is 3D: Yes
> | N: 7064064.24981919 S: 7062068.91228081
> | E: 371187.626007 W: 369196.94006096
> | B: 1000 T: 2000
> | Comment:
> This are 2 tests that I made and I notice that B and T values are the
> values that I put on zshift and height... But this don't indicates nothing
> about the plane... how can I reference the sea level plane? I am a little
> lost here haha.
> Tnks,
> Alec
> From: kratochanna at gmail.com
> Date: Sun, 28 Feb 2016 19:09:03 -0500
> Subject: Re: [GRASS-user] 3d boreholes with v.extrude on different plane
> To: alecventura at hotmail.com
> CC: grass-user at lists.osgeo.org
> What does v.info say?
> On Sun, Feb 28, 2016 at 7:05 PM, Alec Ventura <alecventura at hotmail.com>
> wrote:
> 'as 3d' is selected. I have 83 boreholes and all of then have their base
> on the same plane, and it shouldn't be.
> Tnks,
> Alec
> Date: Sun, 28 Feb 2016 18:02:58 -0500
> Hi,
> there is a switch in the 3D view vector gui to switch between displaying
> as 3D and on a surface. You might check if that could be the problem.
> Anna
> On Sun, Feb 28, 2016 at 5:43 PM, Alec Ventura <alecventura at hotmail.com>
> wrote:
> Hello folks, I am trying, again, to draw some 3d boreholes, I was able to
> draw then but when I was analizing my results I notice that all my
> boreholes was all with the same z value, which is strange since I have
> different zshit and height values for each of my boreholes. So I guess i
> missundestood the zshit value. I need 3d boreholes that are draw from
> different levels (different Z coordinates) and of course with different
> sizes (heigths). Is there a way to do this? what I am missing here? I was
> back to Gene implementation:
> http://osgeo-org.1560.x6.nabble.com/3D-geological-volume-modeling-raster-3D-is-it-really-possible-td4980148.html
> http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
> But then I realize that they boreholes are at same plane too, just don't
> appear to because of perspective.
> I appreciate any help.
> []s
> Alec Ventura.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160228/73608a4c/attachment.html>
