[GRASS-user] 3d boreholes with v.extrude on different plane
Alec Ventura
alecventura at hotmail.com
Mon Feb 29 17:42:23 PST 2016
Sorry my delay, here are 6 of my boreholes. Even that they have different zshift values, they are been draw on the same planeTnks,Alec
Date: Sun, 28 Feb 2016 21:21:04 -0500
Subject: Re: [GRASS-user] 3d boreholes with v.extrude on different plane
To: alecventura at hotmail.com
CC: grass-user at lists.osgeo.org
Could you send me the data using v.pack?
On Sun, Feb 28, 2016 at 7:16 PM, Alec Ventura <alecventura at hotmail.com> wrote:
+----------------------------------------------------------------------------+ | Name: test1 | | Mapset: Map | | Location: Tests | | Database: C:\Users\Vulcan\Documents\grassdata | | Title: | | Map scale: 1:1 | | Name of creator: Vulcan | | Organization: | | Source date: Sun Feb 28 19:14:22 2016 | | Timestamp (first layer): none | |----------------------------------------------------------------------------| | Map format: native | |----------------------------------------------------------------------------| | Type of map: vector (level: 2) | | | | Number of points: 0 Number of centroids: 0 | | Number of lines: 0 Number of boundaries: 0 | | Number of areas: 0 Number of islands: 0 | | Number of faces: 25 Number of kernels: 1 | | Number of volumes: 0 Number of holes: 0 | | | | Map is 3D: Yes | | Number of dblinks: 1 | | | | Projection: UTM (zone invalid) | | | | N: 7074915.22090919 S: 7072919.88337081 | | E: 383218.654546 W: 381227.96859996 | | B: 100 T: 2000 | | | | Digitization threshold: 0 | | Comment: | | Generated by v.extrude from vector map <tmp at Map> | +----------------------------------------------------------------------------+
and
+----------------------------------------------------------------------------+ | Name: test2 | | Mapset: Map | | Location: Tests | | Database: C:\Users\Vulcan\Documents\grassdata | | Title: | | Map scale: 1:1 | | Name of creator: Vulcan | | Organization: | | Source date: Sun Feb 28 19:15:15 2016 | | Timestamp (first layer): none | |----------------------------------------------------------------------------| | Map format: native | |----------------------------------------------------------------------------| | Type of map: vector (level: 2) | | | | Number of points: 0 Number of centroids: 0 | | Number of lines: 0 Number of boundaries: 0 | | Number of areas: 0 Number of islands: 0 | | Number of faces: 25 Number of kernels: 1 | | Number of volumes: 0 Number of holes: 0 | | | | Map is 3D: Yes | | Number of dblinks: 1 | | | | Projection: UTM (zone invalid) | | | | N: 7064064.24981919 S: 7062068.91228081 | | E: 371187.626007 W: 369196.94006096 | | B: 1000 T: 2000 | | | | Digitization threshold: 0 | | Comment: | | Generated by v.extrude from vector map <tmp at Map> | +----------------------------------------------------------------------------+
This are 2 tests that I made and I notice that B and T values are the values that I put on zshift and height... But this don't indicates nothing about the plane... how can I reference the sea level plane? I am a little lost here haha.Tnks,Alec
Date: Sun, 28 Feb 2016 19:09:03 -0500
What does v.info say?
On Sun, Feb 28, 2016 at 7:05 PM, Alec Ventura <alecventura at hotmail.com> wrote:
'as 3d' is selected. I have 83 boreholes and all of then have their base on the same plane, and it shouldn't be.Tnks,Alec
Date: Sun, 28 Feb 2016 18:02:58 -0500
there is a switch in the 3D view vector gui to switch between displaying as 3D and on a surface. You might check if that could be the problem.
Anna
On Sun, Feb 28, 2016 at 5:43 PM, Alec Ventura <alecventura at hotmail.com> wrote:
Hello folks, I am trying, again, to draw some 3d boreholes, I was able to draw then but when I was analizing my results I notice that all my boreholes was all with the same z value, which is strange since I have different zshit and height values for each of my boreholes. So I guess i missundestood the zshit value. I need 3d boreholes that are draw from different levels (different Z coordinates) and of course with different sizes (heigths). Is there a way to do this? what I am missing here? I was back to Gene implementation:
http://osgeo-org.1560.x6.nabble.com/3D-geological-volume-modeling-raster-3D-is-it-really-possible-td4980148.htmlhttp://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
But then I realize that they boreholes are at same plane too, just don't appear to because of perspective.I appreciate any help.[]sAlec Ventura.
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0006.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0007.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0008.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0009.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0010.obj>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160229/8a38e85e/attachment-0011.obj>
