[GRASS-user] home directory for import files for grass 7.02 on linux
Jim Maas j.maas at uea.ac.uk
Wed Jan 6 07:02:04 PST 2016
Thanks for this, however it seems to work for the current session only.
If I save the file and exit, shutting down grass completely, and then it
start it again, it reverts to ~/.  Am I doing something wrong?
Thanks,
J
On 05/01/16 21:17, Veronica Andreo wrote:
> Hi
> 2016-01-05 15:42 GMT-03:00 Vaclav Petras <wenzeslaus at gmail.com
> <mailto:wenzeslaus at gmail.com>>:
>     On Tue, Jan 5, 2016 at 11:41 AM, Jim Maas <j.maas at uea.ac.uk
>     <mailto:j.maas at uea.ac.uk>> wrote:
>         When I start grass and then attempt to import a vector or
>         raster file, it begins looking in my ~/ directory.  It would
>         be much more convenient if I could tell it to start looking in
>         a subdirectory where I'm working.  Is there a setting
>         somewhere to change where the "import raster data" file
>         browser starts looking ? I'm thinking something analogous to a
>         "home" directory?
>     The GUI dialog opens in the current working directory (result of
>     `pwd` or $PWD). It is the current working dir of GUI, i.e. the one
>     which was current when g.gui was started (e.g. automatically
>     during start of GRASS GIS).
>     If you change dir in terminal, GUI doesn't see this (the process
>     is Independent). You can, however, change the working dir for GUI,
>     e.g. by typing cd into the GUI Command Console.
> You can also change the working directory in the GUI. Go to Settings
> --> GRASS working environment --> Change working directory
> Best,
> Vero
Dr. Jim Maas
