[GRASS-user] Problems to show 3d boreholes
Anna Petrášová
kratochanna at gmail.com
Tue Jan 12 18:30:25 PST 2016
On Tue, Jan 12, 2016 at 7:15 PM, Alec Ventura <alecventura at hotmail.com>
wrote:
> Im trying to draw some 3d boreholes, i have based my attempts on gene
> solution:
> http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
> I believe im on the right path, but by some reason when i change to 3d it
> gave me the fallow message:
> Error loading vector map <bore1 at Map1>
> No points from vector map <bore2 at Map1> fall within current
> region
> And it happens for all boreholes, when i access theyr metadata it gives:
> | Map format: native
> | Type of map: vector (level: 2)
> | Number of points: 0 Number of centroids: 0
> | Number of lines: 0 Number of boundaries: 0
> | Number of areas: 0 Number of islands: 0
> | Number of faces: 25 Number of kernels: 1
> | Number of volumes: 0 Number of holes: 0
> | Map is 3D: Yes
> | Number of dblinks: 1
> | Projection: UTM (zone invalid)
> | N: 7064064.24981919 S: 7062068.91228081
> | E: 371187.626007 W: 369196.94006096
> | B: 148 T: 496
> | Digitization threshold: 0
> | Comment:
> | Generated by v.extrude from vector map <tmp at Map1>
> Im using UTM 22s, but on metadata it says UTM (zone invalid).
> But on 2d, it appears on viewport.
> Any ideas?
> Tnks.
Perhaps you could share the data to test? You can use v.pack.
Best,
Anna
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160112/2abc049a/attachment.html>
