[GRASS-user] Problems to show 3d boreholes
Alec Ventura
alecventura at hotmail.com
Mon Jan 18 16:09:07 PST 2016
So, i as able to find some time to work here again... I have created a new location using the shape file as source for it, and when i choose the file, it successfully recognize the location as UTM 22s.But right after GRASS had opened and i just imported the shape to my viewport and see the metadata of shape, it again says : Projection: UTM (zone invalid)
My steps:created a location based on shape file attached,1 - run: d.vect map=Pocos_UTM at PERMANENT2 - run: v.info map=Pocos_UTM at PERMANENT
ps: i just have imported the .shp file
Date: Tue, 12 Jan 2016 21:30:25 -0500
Subject: Re: [GRASS-user] Problems to show 3d boreholes
To: alecventura at hotmail.com
CC: grass-user at lists.osgeo.org
On Tue, Jan 12, 2016 at 7:15 PM, Alec Ventura <alecventura at hotmail.com> wrote:
Im trying to draw some 3d boreholes, i have based my attempts on gene solution:http://osgeo-org.1560.x6.nabble.com/Automatic-3D-geological-boreholes-representation-automate-v-extrude-from-a-table-my-solution-in-Pythn-td4978801.html
I believe im on the right path, but by some reason when i change to 3d it gave me the fallow message:
Error loading vector map <bore1 at Map1>No points from vector map <bore2 at Map1> fall within currentregion
And it happens for all boreholes, when i access theyr metadata it gives:
| Map format: native | |----------------------------------------------------------------------------| | Type of map: vector (level: 2) | | | | Number of points: 0 Number of centroids: 0 | | Number of lines: 0 Number of boundaries: 0 | | Number of areas: 0 Number of islands: 0 | | Number of faces: 25 Number of kernels: 1 | | Number of volumes: 0 Number of holes: 0 | | | | Map is 3D: Yes | | Number of dblinks: 1 | | | | Projection: UTM (zone invalid) | | | | N: 7064064.24981919 S: 7062068.91228081 | | E: 371187.626007 W: 369196.94006096 | | B: 148 T: 496 | | | | Digitization threshold: 0 | | Comment: | | Generated by v.extrude from vector map <tmp at Map1> | +----------------------------------------------------------------------------+
Im using UTM 22s, but on metadata it says UTM (zone invalid).
But on 2d, it appears on viewport.Any ideas?Tnks.
Perhaps you could share the data to test? You can use v.pack.
Best,
Anna
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160118/3f85536c/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160118/3f85536c/attachment.zip>
