[GRASS-user] UTM 33x
    Helmut Kudrnovsky
    hellik at web.de
    Sun Jul 17 06:36:17 PDT 2016
>If I could get GRASS to define the lat,lon boundaries as I tried to do in my
last email, but without >crashing, wouldn't that solve this?
mybe yes
>And perhaps I'm still confused, but the projection is *known*, even if it
isn't encoded in this file.
that's the point: the file itself is missing the projection information, see
your gdalinfo output:
"Coordinate System is `'"
and this information is needed for accurate re-projection for GIS.
>If this were known as 33N instead of 33X, I could define a location with an
EPSG code, and then import >with "r.in.gdal -o", where "-o" is "Override
projection (use location's projection)".
that would be the first what I may do (as mentioned in the GDAL ML thread):
try the data to import into  UTM 33N location and see if there are
distortions or any other problems at a first step.
another idea:
ask in the proj-ML (http://lists.maptools.org/mailman/listinfo/proj) and
maybe there metacrs (https://lists.osgeo.org/mailman/listinfo/metacrs).
the former is known for good advices for defining projections.
HTH
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/UTM-33x-tp5276714p5276758.html
Sent from the Grass - Users mailing list archive at Nabble.com.
