[GRASS-user] Pansharpening Landsat 8 Imagery
Michele Toma
michele.toma at airborne.aero
Mon Jul 18 16:49:44 PDT 2016
Hi Vero,
Thanks for the link. I believe the tutorial that I was originally following was the same as what you listed – just on a different site.
Paul Shapley was kind enough to share his tutorial (http://www.paulshapley.com/2014/04/processing-landsat-8-bands-in-grass-gis.html) which has worked for me. (Thanks Paul!)
For anyone that is interested, I followed Paul’s tutorial and was able to get a pansharpened image. I did end up color balancing (i.colors.enhance) as a final step because urban areas were extremely washed out. This corrected the problem and I now have an image that has been pansharpened with natural colors.
(Note: I used version 7.0.4 and installed the i.fusion.brovey extension as I believe this was replaced by i.pansharpen. To do this – Settings -> Addons extensions -> Install extension from addons. Then search for i.fusion.brovey in the “imagery” drop down.)
Thanks again for all the help!
-Michele
From: Veronica Andreo [mailto:veroandreo at gmail.com]
Sent: Monday, July 18, 2016 12:41 PM
To: Michele Toma
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Pansharpening Landsat 8 Imagery
Hello Michele,
I haven't tried myself, but have you seen Markus's blog from some time ago??
http://courses.neteler.org/processing-landsat-8-data-in-grass-gis-7-rgb-composites-and-pan-sharpening/
Maybe useful :)
Best,
Vero
2016-07-18 12:00 GMT-03:00 Michele Toma <michele.toma at airborne.aero<mailto:michele.toma at airborne.aero>>:
Hi everyone,
I was wondering if anyone had any suggestions or workarounds to the issue that I am having with pansharpening Landsat imagery? My email below has the steps that I took to attempt to pansharpen, but once I create a natural color image and run the pansharpen tool, I end up with distorted colors. Are there any other methods that I should try?
Thanks in advance,
Michele
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org>] On Behalf Of Michele Toma
Sent: Wednesday, July 13, 2016 5:39 PM
To: grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
Subject: [GRASS-user] Pansharpening Landsat 8 Imagery
Hi everyone,
I am having difficulty with pansharpening Landsat 8 imagery using this tutorial: http://planet.qgis.org/planet/tag/landsat/. I am able to create a natural color image, but the pansharpening results in images with distorted colors.
Here are the steps that I have followed:
1. Import all Landsat 8 bands to GRASS 7.0.4
a. r.in.gdal input=C:\Users\Michele\Desktop\LC81100362016082LGN00\LC81100362016082LGN00_B1.TIF output=LC81100362016082LGN00_B1 -k -e
2. Converted digital number data to reflectance using i.landsat.toar
a. i.landsat.toar input=LC81100362016082LGN00_B output=LC81100362016082LGN00_refl metfile=C:\Users\Michele\Desktop\LC81100362016082LGN00\LC81100362016082LGN00_MTL.txt sensor=oli8 date=2016-03-22
3. Color balanced using i.colors.enhance for bands 4, 3, 2 as RGB respectively
a. i.colors.enhance red=LC81100362016082LGN00_refl4 at Osaka green=LC81100362016082LGN00_refl3 at Osaka blue=LC81100362016082LGN00_refl2 at Osaka
4. Displayed RGB map using bands 4, 3, 2 (I get a really great natural color image)
5. Pansharpened bands 4, 3, 2 using band 8 as the panchromatic band with the IHS method
a. i.pansharpen red=LC81100362016082LGN00_refl4 at Osaka green=LC81100362016082LGN00_refl3 at Osaka blue=LC81100362016082LGN00_refl2 at Osaka pan=LC81100362016082LGN00_refl8 at Osaka output=LC81100362016082LGN00_ihs method=ihs
6. Displayed RGB map with the “pansharpened” bands for 4, 3, 2
7. Result: An image that is entirely gray (I found this link that says to use i.fusion.hpf, but following those instructions, I get “'make' is not recognized as an internal or external command, operable program or batch file.” http://gis.stackexchange.com/questions/111763/pan-sharpen-landsat-8-using-grass-7 Am I supposed to use the GUI for this?)
From searching online, I have found that the i.pansharpen module doesn’t take 16 bit imagery (which Landsat imagery is) but rather 8 bit. I found this link (http://gis.stackexchange.com/questions/39174/how-to-color-balance-false-composites-of-pan-sharpened-landsat-images-in-grass/67319#67319) that says to rescale the image. I attempted this twice:
1. When I run it on the bands produced after running the i.landsat.toar module, I get numbers such as min=-0.00813278402972343 and max=1.58301384751301. After rescaling the images to 0-255 and proceeding with step 3 I end up with an entirely white image.
2. However, if I rescale the original bands which all have ranges of 0-65535, to 0-255, then pansharpen, the result is a washed out version of the natural color image. I believe this has been pansharpened, but the colors are off. I also attempted to color balance the pansharpened bands but was unsuccessful as well.
Am I rescaling the images incorrectly or is there another step I am getting wrong? Any guidance would be greatly appreciated.
Thank you,
Michele Toma
www.airborne.aero<http://www.airborne.aero>
[New Small2]
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160718/e8c46c24/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160718/e8c46c24/attachment-0001.jpg>
