[GRASS-user] Pansharpening Landsat 8 Imagery
Moritz Lennert
mlennert at club.worldonline.be
Tue Jul 19 02:56:56 PDT 2016
On 19/07/16 09:40, Nikos Alexandris wrote:
> Hello Michele,
> * Michele Toma:
> on i.fusion.hpf,
>> 7. Result: An image that is entirely gray (I found this link that
>> says to use i.fusion.hpf, but following those instructions, I get
>> "'make' is not recognized as an internal or external command, operable
>> program or batch file."
>> http://gis.stackexchange.com/questions/111763/pan-sharpen-landsat-8-using-grass-7
>> Am I supposed to use the GUI for this?)
> You can use the module from either the GUI or the TUI, within from a
> running GRASS-GIS session.
> I know that people have installed and used it in Windows too. I have
> never had the opportunity to test it on a Windows system myself though.
> How did you try to install it?
> I (still!) have to look and update (ie merge a pull request from
> Panagiotis Mavrogiorgos which might fix path name issues in Windows).
How about putting it into the addon repository ?
Moritz
