[GRASS-user] Pansharpening Landsat 8 Imagery
Nikos Alexandris
nik at nikosalexandris.net
Tue Jul 19 00:40:17 PDT 2016
Hello Michele,
* Michele Toma:
on i.fusion.hpf,
>7. Result: An image that is entirely gray (I found this link that
>says to use i.fusion.hpf, but following those instructions, I get
>"'make' is not recognized as an internal or external command, operable
>program or batch file."
>http://gis.stackexchange.com/questions/111763/pan-sharpen-landsat-8-using-grass-7
>Am I supposed to use the GUI for this?)
You can use the module from either the GUI or the TUI, within from a
running GRASS-GIS session.
I know that people have installed and used it in Windows too. I have
never had the opportunity to test it on a Windows system myself though.
How did you try to install it?
I (still!) have to look and update (ie merge a pull request from
Panagiotis Mavrogiorgos which might fix path name issues in Windows).
Nikos
