[GRASS-user] Exporting RGB Composite Images to GeoTIFF
Moritz Lennert
mlennert at club.worldonline.be
Fri Jul 22 02:12:06 PDT 2016
On 21/07/16 16:27, Markus Neteler wrote:
> Hi,
> On Thu, Jul 21, 2016 at 2:53 AM, Michele Toma
> <michele.toma at airborne.aero <mailto:michele.toma at airborne.aero>> wrote:
> Hi everyone (again),____
> __ __
> I am having trouble exporting a composite RGB image into a GeoTIFF
> format that I can open in Global Mapper, Photoshop, or other
> programs. This is using Landsat 8 imagery. I am able to open the
> composite image in QGIS, but not in Global Mapper or Photoshop. ____
> __ __
> Below is a list of steps that I took to get the image. I am unsure
> of what settings to use when using r.out.gdal to export my image so
> that it works in other programs. I am using GRASS 7.0.4.____
> __ __
> __1. __Import Landsat 8 imagery____
> __2. __Convert the DN to reflectance/radiance____
> __a. __i.landsat.toar input=LC81100362016082LGN00_B
> output=LC81100362016082LGN00_refl
> metfile=LC81100362016082LGN00_MTL.txt____
> __3. __Perform pansharpening with i.fusion.brovey addon____
> __a. __i.fusion.brovey -l
> ms1=LC81100362016082LGN00_refl2 at Osaka
> ms2=LC81100362016082LGN00_refl3 at Osaka
> ms3=LC81100362016082LGN00_refl4 at Osaka
> pan=LC81100362016082LGN00_refl8 at Osaka output_prefix=brovey
> BTW: this method is superior (the addon can be installed with g.extension):
> https://github.com/NikosAlexandris/i.fusion.hpf
The addon is not in the addons repository, so you cannot install it with
a simple g.extension i.fusion.hpf. In GRASS 7.2 / trunk you can install
it with g.extension by downloading the source code and pointing the url=
parameter of g.extension to the source code directory.
I hope that the code will be put into the addons repository, soon.
Moritz
