[GRASS-user] Pansharpening Landsat 8 Imagery
Helmut Kudrnovsky
hellik at web.de
Fri Jul 29 10:36:28 PDT 2016
Markus Neteler wrote
> On Tue, Jul 19, 2016 at 9:40 AM, Nikos Alexandris
> nik@
> > wrote:
>> You can use the module from either the GUI or the TUI, within from a
>> running GRASS-GIS session.
>> I know that people have installed and used it in Windows too. I have
>> never had the opportunity to test it on a Windows system myself though.
> Now it is also available for Windows (the Windows Addons are compiled
> on a weekly base)
> https://wingrass.fsv.cvut.cz/grass70/x86_64/addons/latest/
> Hence, g.extension or the extension menu entry will fetch it for you.
installing by g.extension in winGRASS7 works, but starting the script:
C:\>i.fusion.hpf --help
Description:
Fusing high resolution Panchromatic and low resolution Multi-Spectral data
base
d on the High-Pass Filter Addition technique (Gangkofner, 2008)
Keywords:
imagery, fusion, sharpening, high pass filter, HPFA
Usage:
i.fusion.hpf.py [-l2c] pan=filename msx=filename(s)[,filename(s),...]
suffix=suffix string [ratio=rational number] [center=string]
[center2=string] [modulation=string] [modulation2=string]
[trim=rational number] [--overwrite] [--help] [--verbose] [--quiet]
[--ui]
Flags:
-l Linearly match histogram of Pan-sharpened output to Multi-Spectral
input
-2 2-Pass Processing (recommended) for large resolution ratio (>=5.5)
-c Match color table of Pan-Sharpened output to Multi-Spectral input
--o Allow output files to overwrite existing files
--h Print usage summary
--v Verbose module output
--q Quiet module output
--qq Super quiet module output
--ui Force launching GUI dialog
Parameters:
pan High resolution Panchromatic image
msx Low resolution Multi-Spectral image(s)
suffix Suffix for output image(s)
Names of Pan-Sharpened image(s) will end with this suffix
default: hpf
ratio Custom ratio
Custom ratio overriding standard calculation
options: 1.0-10.0
center Center cell value
Center cell value of the High-Pass-Filter
options: low,mid,high
default: low
center2 2nd Pass center cell value
Center cell value for the second High-Pass-Filter (use -2
flag)
default: low
modulation Modulation level
Modulation level weighting the HPF image determining
crispness
options: min,mid,max
default: mid
modulation2 2nd Pass modulation level (use -2 flag)
Modulation level weighting the second HPF image determining
cri
spness (use -2 flag)
default: mid
min: Minimum: 0.25
mid: Mid: 0.35
max: Maximum: 0.5
trim Trimming factor
Trim output border pixels by a factor of the pixel size of
the
low resolution image. A factor of 1.0 may suffice.
This application has requested the Runtime to terminate it in an unusual
way.
Please contact the application's support team for more information.
terminating in an unusal way.
any idea?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pansharpening-Landsat-8-Imagery-tp5276266p5278737.html
Sent from the Grass - Users mailing list archive at Nabble.com.
