[GRASS-user] Pansharpening Landsat 8 Imagery
Helmut Kudrnovsky
hellik at web.de
Fri Jul 29 11:00:00 PDT 2016
Helmut Kudrnovsky wrote
> Markus Neteler wrote
>> On Tue, Jul 19, 2016 at 9:40 AM, Nikos Alexandris
>> nik@
>> > wrote:
>>> You can use the module from either the GUI or the TUI, within from a
>>> running GRASS-GIS session.
>>> I know that people have installed and used it in Windows too. I have
>>> never had the opportunity to test it on a Windows system myself though.
>> Now it is also available for Windows (the Windows Addons are compiled
>> on a weekly base)
>> https://wingrass.fsv.cvut.cz/grass70/x86_64/addons/latest/
>> Hence, g.extension or the extension menu entry will fetch it for you.
> installing by g.extension in winGRASS7 works, but starting the script:
> C:\>i.fusion.hpf --help
> terminating in an unusal way.
> any idea?
tested on the command line in winGRASS73
g.gisenv set=DEBUG=3
i.fusion.hpf pan=lsat7_2000_80a
msx=lsat7_2000_30a,lsat7_2000_20a,lsat7_2000_10a suffix=my
|! Original Region restored
D1/3: G_set_program_name(): g.message
D2/3: G_file_name(): path = J:\gisdata\nc_spm_08_grass7\user1
D1/3: g.message message=
>>> Hint, rebalancing colors (via i.colors.enhance) may improve appearance
>>> of RG
B composites! debug=1 -i
of RGB composites!
D1/3: grass.script.core.start_command(): g.remove --q -f pattern=tmp.5792*
type=
raster
D1/3: G_set_program_name(): g.remove
D2/3: G_file_name(): path = J:\gisdata\nc_spm_08_grass7\user1\cell
WARNING: No data base element files found
This application has requested the Runtime to terminate it in an unusual
way.
Please contact the application's support team for more information
g.list type=raster mapset=user1
lsat7_2000_10a
lsat7_2000_10a.my
lsat7_2000_20a
lsat7_2000_20a.my
lsat7_2000_30a
lsat7_2000_30a.my
lsat7_2000_80a
r.info map=lsat7_2000_10a.my at user1
| Map: lsat7_2000_10a.my at user1 Date: Fri Jul 29 20:07:30 2016
| Mapset: user1 Login of Creator: normal
| DataBase: J:\gisdata
| Title: tmp.5792.4_msx_hpf
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: DCELL
| Rows: 950
| Columns: 1054
| Total Cells: 1001300
| Projection: Lambert Conformal Conic
| N: 228513 S: 214975.5 Res: 14.25
| E: 645012 W: 629992.5 Res: 14.25
| Range of data: min = 46.8253308406372 max = 292.357619939526
| Data Description:
| generated by r.mapcalc
| Comments:
| tmp.5792.4_msx_blnr + tmp.5792.4_pan_hpf * 0.019623261
| Weigthing applied: 13.976 / 178.050 * 0.250
so it seems the script calculates the images with higher resolution, but
terminates at some stage before finishing correctly
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Pansharpening-Landsat-8-Imagery-tp5276266p5278738.html
Sent from the Grass - Users mailing list archive at Nabble.com.
