[GRASS-user] FW: Temporal + export
    Luca Delucchi
    lucadeluge at gmail.com
    Thu Jun  9 06:19:20 PDT 2016
On 13 May 2016 at 20:07, Veronica Andreo <veroandreo at gmail.com> wrote:
> Hey, Mati! Hola!
Hi Vero, Matias
> @Luca, might the error and/or message be related to [2]?
I don't think so
>> ERROR: La exportación raster puede resultar en una pérdida completa de
>> datos, cancelando.
>> Traceback (most recent call last):
>>   File "C:\OSGEO4~1\apps\grass\grass-7.0.4/scripts/t.rast.ex
>> port.py", line 87, in <module>
>>     main()
>> port.py", line 82, in main
>>     _input, output, compression, directory, where, _format,
>> "strds")
>>   File "C:\OSGEO4~1\apps\grass\grass-7.0.4\etc\python\grass\
>> temporal\stds_export.py", line 298, in export_stds
>>     rows, tar, list_file, new_cwd, fs, format_)
>> temporal\stds_export.py", line 97, in
>> _export_raster_maps_as_gdal
>>     shutil.rmtree(new_cwd)
>>   File "C:\OSGEO4~1\apps\Python27\lib\shutil.py", line 252,
>> in rmtree
>>     onerror(os.remove, fullname, sys.exc_info())
>>   File "C:\OSGEO4~1\apps\Python27\lib\shutil.py", line 250,
>> in rmtree
>>     os.remove(fullname)
>> WindowsError: [Error 32] El proceso no tiene acceso al
>> archivo porque está siendo utilizado por otro proceso:
>> 'C:\\SIG\\Grass\\tmp883adw\\archive'
>> (Fri May 13 13:09:21 2016) Comando finalizado. (2 segundos)
>> (Fri May 13 13:14:02 2016)
it seems related to r.out.gdal, Matias could you try again the command?
>> Some new idea?
>> Thanks!!!
> Does r.out.gdal for only one map works? Something like
> r.out.gdal input=LST output=LST.tif format=GTiff type=UInt16
Matias is this working for you?
> Let us know :)
> Vero
ciao
Luca
www.lucadelu.org
