[GRASS-user] use of g.list inside r.mapcalc expression
Veronica Andreo
veroandreo at gmail.com
Wed Jun 15 07:17:20 PDT 2016
Cool!
Thanks my friend!
A slightly modified version did the trick! My previous attempt included a
bunch of nested for loops that took forever :-/
map=`g.list rast pat=MOD13Q1*_NDVI`
for m in ${map}; do
i=`echo $m | cut -c 1-23`
echo $m $i
r.mapcalc --o \
expression="${m} = if("${i}"_pixel_reliability == 0, ${m}, null())"
done
Cheers!
Vero
2016-06-15 10:36 GMT-03:00 Sajid Pareeth <spareeth at gmail.com>:
> Hi Vero
> If I got you right, may be this could be a better approach,
> #Assuming you are using MOD13Q1 product, and for example maps from
> MOD13Q1.A2015353.h18v05.006.2016007180711.hdf;
> map=`g.list rast pat=MOD13*_EVI`
> for tile in ${map}; do
> ## Put the common part (In this case - MOD13Q1.A2015353.h18v05) of the
> map name into a variable.
> i=`echo $map|cut -c1-23`
> r.mapcalc --o expression="${map} = if(${i}_pixel_reliability` == 0,
> ${map}, null())"
> done
> Sajid
> On Wed, Jun 15, 2016 at 2:58 PM, Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hello everybody,
>> Is it possible to use r.mapcalc with `g.list` as part of the
>> expression??? Something like:
>> tiles=(h11v11 h12v11 h12v12)
>> for tile in ${tiles[*]}
>> do
>> r.mapcalc --o expression="`g.list rast pat=MOD13*$tile_EVI` =
>> if(`g.list rast pat=MOD13*$tile_pixel_reliability` == 0, `g.list rast
>> pat=MOD13*$tile_EVI`, null())"
>> done
>> it worked only once in a test case with one image per tile... when I
>> tried to run it again for the whole set, i get parse error:
>> syntax error, unexpected ';', expecting '('
>> syntax error, unexpected ';', expecting ')'
>> Parse error
>> ERROR: parse error
>> Which would be best practice in this case? Is this use even possible?
>> I know I can register maps in temporal framework and use
>> t.rast.mapcalc, but I want to keep year and doy in mapnames and
>> neither t.rast.mapcalc nor t.rast.algebra have granularity suffix
>> option yet (only numerical suffix).
>> Ah, I use grass trunk (7.3) freshly updated to r68692.
>> thanks much in advance!
>> Vero
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160615/06a58072/attachment.html>
