[GRASS-user] Fwd: v.label utf8 possible?
Vaclav Petras wenzeslaus at gmail.com
Mon Jun 27 09:50:02 PDT 2016
On Sun, Jun 26, 2016 at 7:38 AM, Robert Kuszinger <kuszinger at giscom.hu>
wrote:
> As a workaround I've created a script and discovered that I could simulate
> the work done by ps.map with some handmade calculations.
> The result is not worse (visually in terms of generated code) than my
> beloved ps.map definition files. I have full control on display, raster,
> vector and other map gadgets (north, scalebar, etc). I use GRASS_RENDER_*
> variables, and all d.* commands. Cairo driver with BMP output is very fast.
> I put each map "layer" into a different BMP files with identicatal
> resolutions.
This sounds good. Perhaps you can share your work at some point. It would
be a good contribution to the discussion about the future of ps.map and d.
commands.
> The resolution is currently a given dpi (300-600) bitmap but I'd like to
> test the toolchain with svg output as well to keep vectors for best print
> process.
Please see:
https://trac.osgeo.org/grass/ticket/3033
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160627/1318b9f7/attachment.html>
