[GRASS-user] GRASS6.4 and GRASS7.0
Vaclav Petras wenzeslaus at gmail.com
Thu Jun 30 07:21:55 PDT 2016
On Thu, Jun 30, 2016 at 6:00 AM, Javier Álvarez Rodríguez <
Javier.Alvarez at cedex.es> wrote:
> Considering the differences in scripts working in GRASS6 and GRASS7,
please note that there is a strong backwards compatibility. For example, G6
option names are still valid (if possible) thanks to this file:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/renamed_options
which is used internally to translate from G6 to G7, so you can use G6
option in G7.
Some removed G6 modules are available in Addons, for example r.los.
> is it possible to install and work with both versions of GRASS?.
I would rather suggest identifying the differences in scripting API and
trying to introduce backwards compatibility if it is missing. Feel free to
open a ticket for the individual issues, so we can solve them on case to
case basis.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160630/d8b0e8be/attachment-0001.html>
