[GRASS-user] features not reachable in network
Will Fields
will.openfields at gmail.com
Thu Jun 30 12:07:52 PDT 2016
Hi all,
I'm trying to measure the distance between points along a vector
representing a stream network. I tried this first with the 'stream' vector
in the North Carolina sample data set, following the example from the
documentation for v.net.allpairs:
1. v.split to split network into segments of a specified length
2. v.net option=nodes to generate network with points at end of segments
3. v.net.allpairs to calculate distance between all pairs of points
This worked fine.
Then I tried this with some new vector data representing a stream that was
created with r.stream.extract. When I ran the v.net.allpairs, I only
receive distances between certain points on the network. Running
v.net.distance returns a message, "WARNING: 232 'from' features were not
reachable".
I tried running the snap tool in v.clean to correct topological issues with
the data, but I'm still getting the same error message.
Does anyone have thoughts on what else I can do to try to resolve this?
Thanks,
Will
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160630/7da61bea/attachment.html>
