[GRASS-user] stream network
Will Fields will.openfields at gmail.com
Wed Mar 2 11:22:22 PST 2016
Hi Janet,
Can you give some more information about what you mean by larger watershed
basins?  Did you do any preprocessing of the elevation raster before you
tried to extract the stream networks?  Were you using an elevation raster
that had been merged from different rasters?  I've ran into issues in the
past where "seams" along the original edges of a raster resulted in odd
stream networks.
Will
On Wed, Mar 2, 2016 at 11:40 AM, Janet Choate <jsc.eco at gmail.com> wrote:
> Hi GRASS community,
> When creating a stream network with r.watershed, I end up with some
> isolated stream segments - particularly in larger watershed basins. Does
> anyone know how to generate a stream network that is fully connected, or
> how to correct this issue?
> thank you,
> Janet
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160302/4d9f6622/attachment.html>
