[GRASS-user] stream network
Stefan Lüdtke
sluedtke at gfz-potsdam.de
Thu Mar 3 01:38:42 PST 2016
Hi Janet,
can you provide a screenshot of the river network, I think that helps to
understand what is going on in your specific case?!
Cheers,
Stefan
On 02/03/16 20:42, Janet Choate wrote:
> Hi Will,
> When running r.watershed on a small 35 hectare watershed, it produces a
> fully connected stream network. However, when running r.watershed on a
> 6400 hectare watershed, the stream network is not fully connected.
> No preprocessing with regards to merging different raster maps, however,
> I did try using r.fill.dir first to deal with any possible depressions
> that might be causing non-connected stream segments.
> thanks,
> Janet
> On Wed, Mar 2, 2016 at 11:22 AM, Will Fields <will.openfields at gmail.com
> <mailto:will.openfields at gmail.com>> wrote:
> Hi Janet,
> Can you give some more information about what you mean by larger
> watershed basins? Did you do any preprocessing of the elevation
> raster before you tried to extract the stream networks? Were you
> using an elevation raster that had been merged from different
> rasters? I've ran into issues in the past where "seams" along the
> original edges of a raster resulted in odd stream networks.
> Will
> On Wed, Mar 2, 2016 at 11:40 AM, Janet Choate <jsc.eco at gmail.com
> <mailto:jsc.eco at gmail.com>> wrote:
> Hi GRASS community,
> When creating a stream network with r.watershed, I end up with
> some isolated stream segments - particularly in larger watershed
> basins. Does anyone know how to generate a stream network that
> is fully connected, or how to correct this issue?
> thank you,
> Janet
> grass-user mailing list
> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Tague Team Lab Manager
> 1005 Bren Hall
> UCSB, Santa Barbara, CA.
Stefan Lüdtke
Section 5.4- Hydrology
Tel.: +49 331 288 2821
Fax: +49 331 288 1570
Email: sluedtke at gfz-potsdam.de
Helmholtz-Zentrum Potsdam
Deutsches GeoForschungsZentrum GFZ
(GFZ German Research Centre for Geoscience)
Stiftung des öff. Rechts Land Brandenburg
Telegrafenberg, 14473 Potsdam
PGP Public Key: http://bit.ly/13d9Sca
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160303/a325b3ed/attachment.sig>
