[GRASS-user] How to define the png image dimensions when using d.mon?
jean pierre huart
jph at openjph.be
Thu Mar 10 00:48:46 PST 2016
I did it also directly in the terminal and it's the same result.
Adding 'width' and 'height' parameters to d.mon has given the expected
result.
viascript.png PNG 1280x960 1280x960+0+0 8-bit DirectClass 72.7KB 0.000u
0:00.000
(NB I tried it before unsuccessfully, but I was not deleting the
existing image, thanks for mentioning it to me).
d.mon still fails for the transparent background.
I used the parameter 'bgcolor' to change the background color, but
declaring bgcolor='none' give me an error.
'transparent' parameter does not exists. Any idea on which parameter to
use for such behaviour?
With these tests, I have the impression that 'GRASS_RENDER_TRANSPARENT',
'GRASS_RENDER_HEIGHT', 'GRASS_RENDER_WIDTH' are not taken into account
by d.mon.
I still have to test all this using another location instead of the
one I've set up.
Jean Pierre Huart
On 09/03/16 20:04, Moritz Lennert wrote:
> On 09/03/16 18:01, jean pierre huart wrote:
>> Launching the two scripts directly in GRASS7 console using my
>> location/mapset give the following results for just one width, height
>> (1280,960):
>> Using d.mon (not ok)
>> viascript.png PNG 640x480 640x480+0+0 8-bit DirectClass 30.5KB 0.000u
>> 0:00.000
> I didn't try in the console, but directly in the terminal. Not sure
> how d.mon and wxGUI console interact.
> Note that d.mon also has width and height parameters. Have you tried
> with those ?
> Moritz
