[GRASS-user] How to define the png image dimensions when using d.mon?
    Moritz Lennert
    mlennert at club.worldonline.be
    Thu Mar 10 01:14:59 PST 2016
On 10/03/16 09:48, jean pierre huart wrote:
> I did it also directly in the terminal and it's the same result.
> With these tests, I have the impression that 'GRASS_RENDER_TRANSPARENT',
> 'GRASS_RENDER_HEIGHT', 'GRASS_RENDER_WIDTH' are not taken into account
> by d.mon.
Thanks for all these tests. Ok, I've just tested and I can confirm that
there seems to be an issue in grass70. Everything works for me in grass71.
Martin has done some serious rewriting of d.mon in trunk (grass71). Too
much to be backported to the stable branch. I don't know if these things
can easily be fixed in grass, or whether this is another serious
argument to release grass sooner rather than later...
In conclusion, if you want to use d.mon, I suggest you try with grass71
for now.
Moritz
