[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Rainer M Krug Rainer at krugs.de
Tue Mar 15 06:03:44 PDT 2016
Adam Dershowitz <adershowitz at exponent.com> writes:
> If people are avoiding a useful system upgrade because of a single
> application, that indicates that the application is important.
> One of the great things about GRASS is that it runs cross platform.  It
> would be a big shame to give that up.  I hope that the project can move
> forward to keep Mac OS support.
I definitely hope so. It is just that among the developers, not many are
using OS X (I am not a developer)!
It is interesting, that GRASS is the only program I know / use, which
does not run under El Capitan. Most of the others had hick ups, but the
problems were solved (XTraFinder is an exception) eventually, and none
requires disabling of SIP.
I don't really understand where the problem with SIP comes in (except of
the DYN_LIB variable?), as what GRASS is doing, nowhere interferes with
the system (XTraFinder uses code Injection to change the behaviour of
the Finder - so that is different).
> I¹ve never used docker, but was just checking up on, and it doesn¹t appear
> to be free, nor does it appear to work on Macs.  I could be wrong about
> either, but GRASS runs natively so well, that there really should not be a
> need to give that up.
See https://www.docker.com/ - docker is open source and it runs on Mac
https://docs.docker.com/engine/installation/mac/ .
But I completely agree that GRASS should stay multi-platform - but I
guess something in the compilation / packaging / running structure has
to change for this.
Cheers,
Rainer
> I believe the one of the reasons for the shift to
> wxpython, years ago, was to keep cross platform support.
> -- Adam
>>> So it looks like this is actually the known problem with System
>>> Integrity Protection. I hate to turn off a security feature, and do
>>> two reboots, to be able to run a single application. Has there been
>>> any progress in getting this fixed?
>>No - I have the feeling that the ones using GRASS on OS X are still
>>avoiding upgrading to El Capitan, and the ones who have are out in the
>>cold. I raised the issue several times already.
>>I slowly really think the best would be to abandon GRASS on OS X and
>>focus on setting up an official docker image which can be used on OS X,
>>Windows and Linux.
>>Please convince me otherwise.
>>Cheers,
>>Rainer
>>> Thanks,
>>> -- Adam
>>> From: Adam Dershowitz <adershowitz at exponent.com>
>>> Date: Monday, March 14, 2016 at 11:21 PM
>>> To: Michael Barton <Michael.Barton at asu.edu>, grass-user grass-user
>>> <grass-user at lists.osgeo.org>
>>> Subject: Re: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>>> wxPython (missing)
>>> And, I just tried to run 6.4, which I still had installed, and it also
>>> won¹t run, but with a different error:
>>> Python 2.7.10 found.
>>> Cleaning up temporary files ...
>>> Starting GRASS ...
>>> Traceback (most recent call last):
>>> File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
>>> line 37, in <module>
>>> from core import globalvar
>>> File
>>>"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/core/globalvar.p
>>>y",
>>> line 74, in <module>
>>> import wx
>>> File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/__init__.py",
>>> line 45, in <module>
>>> from wx._core import *
>>> File
>>> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py",
>>> line 4, in <module>
>>> import _core_
>>> ImportError: dlopen
>>> (/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
>>> 2): Library not loaded:
>>> /Users/Shared/unix/wxpython-cocoa-lion/lib/libwx_osx_cocoau-3.0.dylib
>>> Referenced from:
>>> Reason: image not found
>>> Error in GUI startup. If necessary, please
>>> report this error to the GRASS developers.
>>> Switching to text mode now.
>>> Hit RETURN to continue...
>>> Has anyone had any luck running GRASS on 10.11 at all?
>>> -- Adam
>>> From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of
>>> Date: Monday, February 15, 2016 at 3:24 PM
>>> To: grass-user grass-user <grass-user at lists.osgeo.org>
>>> Subject: [GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with
>>> wxPython (missing)
>>> The packaging seems to have gone awry. I've been out of the country
>>> and then sick since returning. Once I get well enough to get to the
>>> office, I'll try and fix this.
>>> Michael
>>> ____________________
>>> C. Michael Barton
>>> Director, Center for Social Dynamics & Complexity
>>> Professor of Anthropology, School of Human Evolution & Social Change
>>> Head, Graduate Faculty in Complex Adaptive Systems Science
>>> Arizona State University
>>> voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
>>> fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
>>> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>>>     On Feb 15, 2016, at 12:59 PM, grass-user-request at lists.osgeo.org
>>>     wrote:
>>>     From: gene <martin.laloux at gmail.com>
>>>     wxPython (missing)
>>>     Date: February 15, 2016 at 11:55:37 AM MST
>>>     To: <grass-user at lists.osgeo.org>
>>>     With the 7.0.3 version of GRASS GIS on the Mac (M.Barton)
>>>     <http://grassmac.wikidot.com/> I can only launch GRASS-7.0.app
>>>     (7.0.3) in
>>>     text mode.
>>>     When I try to launch the App or use g.gui wxpython in the Grass
>>>     shell the
>>>     error is:
>>>     "Launching <wxpython> GUI in the background, please waitŠ
>>>     ERROR: wxGUI requires wxPython. No module named wxversion
>>>     In the 7.0.2 version, wxPython is installed in
>>>     /Applications/GRASS-7.0.app/Contents/MacOS/etc/python (wx,
>>>     wxpython and
>>>     pyparsing.py and wxversion.py) and it works.
>>>     But none of these files/folders exist in the same folder of the
>>>     7.0.3
>>>     version
>>>     Compilation error ?
>>>     The size of the zip files are also different (80.19 and 83.89 for
>>>     GRASS 7.01
>>>     and GRASS 7.02, 35 .12 for GRASS 7.03)
>>>     Many thanks
>>> grass-user mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>Rainer M. Krug
>>email: Rainer<at>krugs<dot>de
>>PGP: 0x0F52F982
Rainer M. Krug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/941f6561/attachment.sig>
