[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
Rainer M Krug
Rainer at krugs.de
Tue Mar 15 12:05:21 PDT 2016
William Kyngesburye <woklist at kyngchaos.com> writes:
> This is also a known issue, related to but separate from the packaging
> issue. During compilation, GRASS also uses DYLD_LIBRARY_PATH to find
> the in-compilation copies of the libraries so it can run the modules
> to create the help files.
OK - this aligns with what I guessed from the error messages.
So the DYLD_LIBRARY_PATH is only used during compilation - and not
during execution, even without "make install"?
> The packaging issue with DYLD_LIBRARY_PATH can be fixed in packaging
> so that everything within the GRASS app package looks directly inside
> the package for libraries and not rely on DYLD_LIBRARY_PATH.
> Homebrew, Macports and /usr/local builds don't need to worry about it
> because the extra dependencies that are bundled in the app are already
> in their proper place.
OK - so in homebrew (I can't speak for Macports) the issue is at the
moment only the one you discuss below.
> The compilation issue needs work to compile all libraries with the
> temporary path inside the libraries and modules (this part is easy) so
> that during compilation help file generation works.
OK - so can you give me any suggestions how I can solve this to make
GRASS at least compile on homebrew?
Speaking generally - is this really the right approach to take, i.e. use
the generated binaries to generate the help files during installation?
Wouldn't it be much easier to do this during installation?
> And then during installation change all the embedded library paths to
> the final destination (this is harder, to figure out the complex
> makefile include system of GRASS to get this operation in the right
> place).
The paths are in the grass script file? Or in others as well?
Wouldn't it make sense to
1) split the generation of the help files from the build step into a
separate make target
2) call the make target for help pages as a last step in the install
step?
This might make packaging more difficult, but wouldn't it make the whole
process clearer?
> Homebrew, Macports, /usr/local AND app installs do have a problem with
> this.
It worked with Yosemite without problems. So this only needs to be done,
because of the issues you describe above?
> It works for Michael (and me) for the "official" packages because we
> compile on older systems that don't have SIP.
Thanks for these clarifications.
I would very much appreciate if we could see to get the compilation and
installation working using homebrew so that there is at least one way of
t=running GRASS on El Capitan without having to interfere with the
security settings.
Thanks,
Rainer
>> On Mar 15, 2016, at 11:39 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> I tried again to install 7.1 head without GUI using homwbrew, and I get
>> the following error:
>> | bash-4.3$ less /Users/rainerkrug/Library/Logs/Homebrew/grass-71/02.make
>> | bash-4.3$ cd /private/tmp/grass-7120160315-47344-1ybn5ar/scripts/d.rast.leg
>> | bash-4.3$ ls
>> | Makefile d.rast.leg.html d.rast.leg.py
>> | bash-4.3$ make
>> | if [
>> | "/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts/d.rast.leg"
>> | != "" ] ; then
>> | GISRC=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/demolocation/.grassrc71
>> | GISBASE=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0
>> | PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts:$PATH"
>> | PYTHONPATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/etc/python:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/gui/wxpython:$PYTHONPATH"
>> | DYLD_LIBRARY_PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:"
>> | LC_ALL=C
>> | --html-description < /dev/null | grep -v '</body>\|</html>' >
>> | d.rast.leg.tmp.html ; fi
>> | dyld: Library not loaded: /usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.1.svn.dylib
>> | Referenced from:
>> | /private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin/g.parser
>> | Reason: image not found
>> | make: *** [d.rast.leg.tmp.html] Error 1
>> | rm d.rast.leg.tmp.html
>> | bash-4.3$
>> In other words: grass is looking during the compilation for a dynamic
>> library
>> (/usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.1.svn.dylib)
>> which has been created, but will only be there when installing.
>> Also important: this error only occurs when the html manual pages are
>> created!
>> Cheers,
>> Rainer
>> Rainer M Krug <Rainer at krugs.de> writes:
>>> Adam Dershowitz <adershowitz at exponent.com> writes:
>>>> I use Macports for a bunch of other things (and Homebrew is incompatible
>>>> with Macports) So, I figured that I would just tried to install grass7
>>>> using macports. It does seem to install, but the gui doesn’t work:
>>>> $grass70
>>>> Cleaning up temporary files...
>>>> Starting GRASS GIS...
>>>> ERROR: wxGUI requires wxPython. No module named wxversion
>>>> Error in GUI startup. If necessary, please report this error to the GRASS
>>>> developers.
>>>> Switching to text mode now.
>>> I don't use MacPorts - but can you try to install without GUI?
>>>> Hit RETURN to continue...
>>>> This is odd, since wxpython is installed.
>>>> But, it seems like this is a different problem.
>>>> -- Adam
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if
> you ARE a maniacally depressed robot? No, don't try and answer, I'm
> 50,000 times more intelligent than you and even I don't know the
> answer...
> - HitchHiker's Guide to the Galaxy
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/1c18f57d/attachment.sig>
