[GRASS-user] GRASS GIS 7.03 for Mac OS X, problem with wxPython (missing)
William Kyngesburye
woklist at kyngchaos.com
Tue Mar 15 12:37:37 PDT 2016
On Mar 15, 2016, at 2:05 PM, Rainer M Krug <Rainer at krugs.de> wrote:
> William Kyngesburye <woklist at kyngchaos.com> writes:
>> This is also a known issue, related to but separate from the packaging
>> issue. During compilation, GRASS also uses DYLD_LIBRARY_PATH to find
>> the in-compilation copies of the libraries so it can run the modules
>> to create the help files.
> OK - this aligns with what I guessed from the error messages.
> So the DYLD_LIBRARY_PATH is only used during compilation - and not
> during execution, even without "make install"?
No, DYLD_LIBRARY_PATH is also used during execution, that's what's causing trouble in the app bundling.
>> The packaging issue with DYLD_LIBRARY_PATH can be fixed in packaging
>> so that everything within the GRASS app package looks directly inside
>> the package for libraries and not rely on DYLD_LIBRARY_PATH.
>> Homebrew, Macports and /usr/local builds don't need to worry about it
>> because the extra dependencies that are bundled in the app are already
>> in their proper place.
> OK - so in homebrew (I can't speak for Macports) the issue is at the
> moment only the one you discuss below.
>> The compilation issue needs work to compile all libraries with the
>> temporary path inside the libraries and modules (this part is easy) so
>> that during compilation help file generation works.
> OK - so can you give me any suggestions how I can solve this to make
> GRASS at least compile on homebrew?
> Speaking generally - is this really the right approach to take, i.e. use
> the generated binaries to generate the help files during installation?
> Wouldn't it be much easier to do this during installation?
Well, the compilation approach is how it's been done as long as I can remember, it's nothing specific to OS X. Changing this would be major.
>> And then during installation change all the embedded library paths to
>> the final destination (this is harder, to figure out the complex
>> makefile include system of GRASS to get this operation in the right
>> place).
> The paths are in the grass script file? Or in others as well?
No, the paths are embedded in the libraries and binary executables.
> Wouldn't it make sense to
> 1) split the generation of the help files from the build step into a
> separate make target
> 2) call the make target for help pages as a last step in the install
> step?
> This might make packaging more difficult, but wouldn't it make the whole
> process clearer?
>> Homebrew, Macports, /usr/local AND app installs do have a problem with
>> this.
> It worked with Yosemite without problems. So this only needs to be done,
> because of the issues you describe above?
It's specifically an El Capitan+ issue, because of SIP.
>> It works for Michael (and me) for the "official" packages because we
>> compile on older systems that don't have SIP.
> Thanks for these clarifications.
> I would very much appreciate if we could see to get the compilation and
> installation working using homebrew so that there is at least one way of
> t=running GRASS on El Capitan without having to interfere with the
> security settings.
> Thanks,
> Rainer
>>> On Mar 15, 2016, at 11:39 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>>> I tried again to install 7.1 head without GUI using homwbrew, and I get
>>> the following error:
>>> | bash-4.3$ less /Users/rainerkrug/Library/Logs/Homebrew/grass-71/02.make
>>> | bash-4.3$ cd /private/tmp/grass-7120160315-47344-1ybn5ar/scripts/d.rast.leg
>>> | bash-4.3$ ls
>>> | Makefile d.rast.leg.html d.rast.leg.py
>>> | bash-4.3$ make
>>> | if [
>>> | "/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts/d.rast.leg"
>>> | != "" ] ; then
>>> | GISRC=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/demolocation/.grassrc71
>>> | GISBASE=/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0
>>> | PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts:$PATH"
>>> | PYTHONPATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/etc/python:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/gui/wxpython:$PYTHONPATH"
>>> | DYLD_LIBRARY_PATH="/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/scripts:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:/private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/lib:"
>>> | LC_ALL=C
>>> | --html-description < /dev/null | grep -v '</body>\|</html>' >
>>> | d.rast.leg.tmp.html ; fi
>>> | dyld: Library not loaded: /usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.1.svn.dylib
>>> | Referenced from:
>>> | /private/tmp/grass-7120160315-47344-1ybn5ar/dist.x86_64-apple-darwin15.3.0/bin/g.parser
>>> | Reason: image not found
>>> | make: *** [d.rast.leg.tmp.html] Error 1
>>> | rm d.rast.leg.tmp.html
>>> | bash-4.3$
>>> In other words: grass is looking during the compilation for a dynamic
>>> library
>>> (/usr/local/Cellar/grass-71/HEAD/grass-7.1.svn/lib/libgrass_gis.7.1.svn.dylib)
>>> which has been created, but will only be there when installing.
>>> Also important: this error only occurs when the html manual pages are
>>> created!
>>> Cheers,
>>> Rainer
>>> Rainer M Krug <Rainer at krugs.de> writes:
>>>> Adam Dershowitz <adershowitz at exponent.com> writes:
>>>>> I use Macports for a bunch of other things (and Homebrew is incompatible
>>>>> with Macports) So, I figured that I would just tried to install grass7
>>>>> using macports. It does seem to install, but the gui doesn’t work:
>>>>> $grass70
>>>>> Cleaning up temporary files...
>>>>> Starting GRASS GIS...
>>>>> ERROR: wxGUI requires wxPython. No module named wxversion
>>>>> Error in GUI startup. If necessary, please report this error to the GRASS
>>>>> developers.
>>>>> Switching to text mode now.
>>>> I don't use MacPorts - but can you try to install without GUI?
>>>>> Hit RETURN to continue...
>>>>> This is odd, since wxpython is installed.
>>>>> But, it seems like this is a different problem.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
