[GRASS-user] Invalid map size
Marvin Eng knot.tyer at gmail.com
Tue Mar 15 13:05:05 PDT 2016
Anna:
Your solution worked fine for the offending workspace file (*.gxw).
It had
display name="Display 1" . . . .  dim="-32000,-32000,160,39"
I changed that to 300 all round and I am now able to use that gxw with
display 1.
However, I seem to have broken something more basic. No matter how I start
the GRASS GUI (in demolocation or a newly created location or any of my
other locations) I get the same "Invalid map size" message and there is no
monitor.
Is there another 'workspace file' for the start up of GRASS that I should
be looking for to edit?
marvin
On Tue, Mar 15, 2016 at 11:12 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi,
> On Tue, Mar 15, 2016 at 1:28 PM, Marvin Eng <knot.tyer at gmail.com> wrote:
>> I was running winGRASS 7.0.0
>> I don't know what I did but; now when I launch the GUI I get no monitor
>> and a command console message saying:
>> Invalid map size 142,0
>> I installed winGRASS 7.0.3 and launched the GUI and I get the same
>> message.
>> I can get a monitor to open using d.mon start=wx0 in a command layer but
>> when I do that the layer manager stops responding. When I close the monitor
>> (with the x) and go back to the command console there is the following
>> message:
>> ERROR: Rendering failed. Details: Error reading PPM file
>> I can 'work around' this with the "Start new map display" button and
>> closing display 1 - but this is a bit annoying and will require me to redo
>> all my workspace files.
> I've seen this happening before. Open your workspace in a text editor and
> look what you have in tag display, attribute dim. You might have some
> exceptionally large values there. This seems to appear only on Windows when
> you save your workspace while the map window is minimized. You can edit
> this value and put some normal value in there (like 300), save it and try
> to reload it again.
> Anna
>> Marvin Eng
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/3ed99907/attachment.html>
