[GRASS-user] Invalid map size
    Anna Petrášová
    kratochanna at gmail.com
    Tue Mar 15 13:20:11 PDT 2016
On Tue, Mar 15, 2016 at 4:05 PM, Marvin Eng <knot.tyer at gmail.com> wrote:
> Anna:
> Your solution worked fine for the offending workspace file (*.gxw).
> It had
> display name="Display 1" . . . .  dim="-32000,-32000,160,39"
> I changed that to 300 all round and I am now able to use that gxw with
> display 1.
> However, I seem to have broken something more basic. No matter how I start
> the GRASS GUI (in demolocation or a newly created location or any of my
> other locations) I get the same "Invalid map size" message and there is no
> monitor.
> Is there another 'workspace file' for the start up of GRASS that I should
> be looking for to edit?
I think it might be in your settings. Open the workspace which works for
you now and go to GUI settings, check (or leave checked) Save current
window layout as default in general tab and make sure you don't have any
GRASS window minimized and then Save. Try to launch GRASS and it should
work again. I fixed some of these things quite recently, I would have to
check all the use cases again to see if it persists in the recent version.
Anna
> marvin
> On Tue, Mar 15, 2016 at 11:12 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> Hi,
>> On Tue, Mar 15, 2016 at 1:28 PM, Marvin Eng <knot.tyer at gmail.com> wrote:
>>> I was running winGRASS 7.0.0
>>> I don't know what I did but; now when I launch the GUI I get no monitor
>>> and a command console message saying:
>>> Invalid map size 142,0
>>> I installed winGRASS 7.0.3 and launched the GUI and I get the same
>>> message.
>>> I can get a monitor to open using d.mon start=wx0 in a command layer but
>>> when I do that the layer manager stops responding. When I close the monitor
>>> (with the x) and go back to the command console there is the following
>>> message:
>>> ERROR: Rendering failed. Details: Error reading PPM file
>>> I can 'work around' this with the "Start new map display" button and
>>> closing display 1 - but this is a bit annoying and will require me to redo
>>> all my workspace files.
>> I've seen this happening before. Open your workspace in a text editor and
>> look what you have in tag display, attribute dim. You might have some
>> exceptionally large values there. This seems to appear only on Windows when
>> you save your workspace while the map window is minimized. You can edit
>> this value and put some normal value in there (like 300), save it and try
>> to reload it again.
>> Anna
>>> Marvin Eng
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160315/05c48757/attachment-0001.html>
