[GRASS-user] i.atcorr - segfault on OSX
Carlos Grohmann
carlos.grohmann at gmail.com
Fri Mar 18 12:49:07 PDT 2016
Hi all.
I'm trying to run some atmospheric correction of ASTER images. First I
calculated radiance and reflectance (with my own script, not
i.aster.toar). I've tried with radiance and reflectance as input, but both
end up in a segfault.. the parameters file has this content:
10
6 22 13.99 -51.931 -3.355
1
15
-0.100
-1000
72
and this is the call to i.atcorr and the error:
(region is defined to the raster)
i.atcorr --overwrite --verbose input=ast_18560.01.radiance
elevation=srtm_xingu_3sec parameters=params6s_ast_18560.txt
output=ast_18560.01.radiance_atcorr
WARNING: Unknown aerosol model!
wavelength less than 0.25 micron:
let's take s(l)=s(0.25)
* ****************************** 6s version 4.2b
* geometrical conditions identity
* ASTER observation
* month: 6 day: 22
* solar zenith angle: 34.61 deg solar azimuthal angle: 38.12
deg *
* view zenith angle: 0.00 deg view azimuthal angle: 0.00
deg *
* scattering angle: 145.39 deg azimuthal angle difference: 38.12
deg *
* atmospheric model description
* atmospheric model identity :
* tropical (uh2o=4.12g/cm2,uo3=.247cm-atm)
* aerosols type identity :
* user defined aerosols model
* optical condition identity :
* visibility : -0.10 km opt. thick. 550nm : 0.0000
* spectral condition
* target type
* homogeneous ground
* constant reflectance over the spectra 0.000
* target elevation description
* ground pressure [mb] 0.00
* ground altitude [km] 99.990
* gaseous content at target level:
* uh2o= 0.000 g/cm2 uo3= 0.000 cm-atm
* plane simulation description
* plane pressure [mb] 0.00
* plane altitude absolute [km] 396884967424.000
* atmosphere under plane description:
* ozone content 0.000
* h2o content 0.000
* aerosol opt. thick. 550nm 0.000
* atmospheric correction activated
Atmospheric correction...
Segmentation fault: 11
I've tried with 7.0.2 and 6.0.4 versions, both end up in the same error.
If I try to run it from a python script I a bit more information:
grass.run_command('i.atcorr', input=ast_band, elevation='srtm_xingu_3sec',
parameters=fname, output=ast_band+'_atcorr_6s', verbose=True)
WARNING: Unsupported iwave value: 809775095
* ASTER observation
* month: 6 day: 22
* solar zenith angle: 34.65 deg solar azimuthal angle: 38.18
deg *
deg *
* scattering angle: 145.35 deg azimuthal angle difference: 38.18
deg *
* Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
line 394, in run_command
return handle_errors(returncode, returncode, args, kwargs)
File
line 312, in handle_errors
returncode=returncode)
File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/exceptions/__init__.py",
line 68, in __init__
msg = _("Module run %s %s ended with error") % (module, code)
TypeError: 'str' object is not callable
any help is appreciated
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
- Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
________________
Can’t stop the signal.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160318/e2eb6617/attachment.html>
