[GRASS-user] i.atcorr - segfault on OSX
Daniel Victoria
daniel.victoria at gmail.com
Mon Mar 21 04:54:38 PDT 2016
Carlos,
The aerosol model is the 4th line in the parameter file. You have set the
aerosol model to 15. But in the i.atcor manual, the values range from 0 to
11. Could that be the problem? i.atcor issues an unknown aerosol model
warning and assumes you are trying to enter aerosol models by hand. Hence
it sets your visibility to -0.1 (ground altitude) and other parameters
wrong.
Cheers
Daniel
On Fri, Mar 18, 2016 at 4:49 PM, Carlos Grohmann <carlos.grohmann at gmail.com>
wrote:
> Hi all.
> I'm trying to run some atmospheric correction of ASTER images. First I
> calculated radiance and reflectance (with my own script, not
> i.aster.toar). I've tried with radiance and reflectance as input, but both
> end up in a segfault.. the parameters file has this content:
> 10
> 6 22 13.99 -51.931 -3.355
> 1
> 15
> -0.100
> -1000
> 72
> and this is the call to i.atcorr and the error:
> (region is defined to the raster)
> i.atcorr --overwrite --verbose input=ast_18560.01.radiance
> elevation=srtm_xingu_3sec parameters=params6s_ast_18560.txt
> output=ast_18560.01.radiance_atcorr
> WARNING: Unknown aerosol model!
> wavelength less than 0.25 micron:
> let's take s(l)=s(0.25)
> * ****************************** 6s version 4.2b
> * geometrical conditions identity
> * ASTER observation
> * month: 6 day: 22
> * solar zenith angle: 34.61 deg solar azimuthal angle: 38.12
> deg *
> * view zenith angle: 0.00 deg view azimuthal angle: 0.00
> deg *
> * scattering angle: 145.39 deg azimuthal angle difference: 38.12
> deg *
> * atmospheric model description
> * atmospheric model identity :
> * tropical (uh2o=4.12g/cm2,uo3=.247cm-atm)
> * aerosols type identity :
> * user defined aerosols model
> * optical condition identity :
> * visibility : -0.10 km opt. thick. 550nm : 0.0000
> * spectral condition
> * target type
> * homogeneous ground
> * constant reflectance over the spectra 0.000
> * target elevation description
> * ground pressure [mb] 0.00
> * ground altitude [km] 99.990
> * gaseous content at target level:
> * uh2o= 0.000 g/cm2 uo3= 0.000 cm-atm
> * plane simulation description
> * plane pressure [mb] 0.00
> * plane altitude absolute [km] 396884967424.000
> * atmosphere under plane description:
> * ozone content 0.000
> * h2o content 0.000
> * aerosol opt. thick. 550nm 0.000
> * atmospheric correction activated
> Atmospheric correction...
> Segmentation fault: 11
> I've tried with 7.0.2 and 6.0.4 versions, both end up in the same error.
> If I try to run it from a python script I a bit more information:
> grass.run_command('i.atcorr', input=ast_band, elevation='srtm_xingu_3sec',
> parameters=fname, output=ast_band+'_atcorr_6s', verbose=True)
> WARNING: Unsupported iwave value: 809775095
> * ASTER observation
> * month: 6 day: 22
> * solar zenith angle: 34.65 deg solar azimuthal angle: 38.18
> deg *
> deg *
> * scattering angle: 145.35 deg azimuthal angle difference: 38.18
> deg *
> * Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
> line 394, in run_command
> return handle_errors(returncode, returncode, args, kwargs)
> File
> line 312, in handle_errors
> returncode=returncode)
> File
> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/exceptions/__init__.py",
> line 68, in __init__
> msg = _("Module run %s %s ended with error") % (module, code)
> TypeError: 'str' object is not callable
> any help is appreciated
> Carlos
> Prof. Carlos Henrique Grohmann
> Institute of Energy and Environment - Univ. of São Paulo, Brazil
> - Digital Terrain Analysis | GIS | Remote Sensing -
> http://carlosgrohmann.com
> http://orcid.org/0000-0001-5073-5572
> ________________
> Can’t stop the signal.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160321/da568ccc/attachment-0001.html>
