[GRASS-user] select areas
Daniel Torres
nobeeakon at gmail.com
Sat Mar 19 22:10:21 PDT 2016
Thanks for the answer Veronica, sadly it didn't worked. As far as I
understand, using v.select with the flag -r , selects the common boundary
first, so it is the excluded when in the reverse selection is done, don't
understand how exactly to solve that using only v.select. Instead I
v.select(ed) -r , then v.extract centroids, and finally v.select areas that
overlap with centroids.
Meanwhile waiting for the beautiful GRASS 7 for Debian.
Thanks again, and nice day.
Daniel
On Sat, Mar 19, 2016 at 3:07 PM, Veronica Andreo <veroandreo at gmail.com>
wrote:
> Hello Daniel,
> What about using operator=contains and -r flag? Does that work?
> You may also want to update to GRASS 7. Check the manual for v.select [0]
> there, it has been improved a lot with examples for most (if not all)
> operators
> Best,
> Vero
> [0] https://grass.osgeo.org/grass70/manuals/v.select.html
> 2016-03-19 5:39 GMT-03:00 Daniel Torres <nobeeakon at gmail.com>:
>> Hi everybody,
>> I want to select areas that don't overlap with points, using "v.select
>> -r [...] operator=overlap", I get unclosed boundaries and centroids at
>> the places where an area is neighbour of a selected area. I do not
>> understand how to obtain also the common border so to obtain closed
>> boundaries with centroids (areas). I'm using GRASS 6.4, and imported the
>> map of areas from a shapefile...
>> Thanks, and sorry for the simple question.
>> Daniel
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160319/a3b4f574/attachment.html>
