[GRASS-user] select areas
Moritz Lennert mlennert at club.worldonline.be
Sun Mar 20 05:28:45 PDT 2016
On 20/03/16 06:10, Daniel Torres wrote:
> Thanks for the answer Veronica, sadly it didn't worked. As far as I
> understand, using v.select with the flag -r , selects the common
> boundary first, so it is the excluded when in the reverse selection is
> done, don't understand how exactly to solve that using only v.select.
> Instead I v.select(ed) -r , then v.extract centroids, and finally
> v.select areas that overlap with centroids.
I don't really understand why there are "common boundaries" between
points and areas ? Could you provide a reproducible example, using the
NC demo data, so that we can understand what exactly is the issue ?
Moritz
