[GRASS-user] i.atcorr returning empty raster and not respecting input parameters [WAS: i.atcorr - segfault on OSX]
Carlos Grohmann
carlos.grohmann at gmail.com
Mon Mar 21 07:40:58 PDT 2016
Thanks Daniel!
That was really dumb of not double-checking the input parameters..
Now another problem: the resulting image is empty! r.info returns "min =
nan max = nan".
I tried with radiance and reflectance as inputs. One thing that I realized
is that, even though I'm not setting it to rescale the output range, it's
doing it:
| Comments:
| i.atcorr --overwrite --verbose -r input="ast_18560.01.toa_reflectanc\
| e at lateritas" range=0,255 elevation="srtm_xingu_3sec at lateritas" param\
| eters="/Volumes/MacintoshHD2/Dropbox/USP/projetosPesquisa/Xingu_late\
| ritas/aster/params6s_ast_18560.txt" output="ast_18560.01.toa_reflect\
| ance_atcorr_6s" rescale=0,255
Here I didn't set neither range nor rescale (left them blank), but
apparently the command is not respecting my choices. bug detected?
After this I tried setting the input range and rescale options, but without
success. Still an empty raster...
best
Carlos
On Mon, Mar 21, 2016 at 8:54 AM, Daniel Victoria <daniel.victoria at gmail.com>
wrote:
> Carlos,
> The aerosol model is the 4th line in the parameter file. You have set the
> aerosol model to 15. But in the i.atcor manual, the values range from 0 to
> 11. Could that be the problem? i.atcor issues an unknown aerosol model
> warning and assumes you are trying to enter aerosol models by hand. Hence
> it sets your visibility to -0.1 (ground altitude) and other parameters
> wrong.
> Cheers
> Daniel
> On Fri, Mar 18, 2016 at 4:49 PM, Carlos Grohmann <
> carlos.grohmann at gmail.com> wrote:
>> Hi all.
>> I'm trying to run some atmospheric correction of ASTER images. First I
>> calculated radiance and reflectance (with my own script, not
>> i.aster.toar). I've tried with radiance and reflectance as input, but both
>> end up in a segfault.. the parameters file has this content:
>> 10
>> 6 22 13.99 -51.931 -3.355
>> 1
>> 15
>> -0.100
>> -1000
>> 72
>> and this is the call to i.atcorr and the error:
>> (region is defined to the raster)
>> i.atcorr --overwrite --verbose input=ast_18560.01.radiance
>> elevation=srtm_xingu_3sec parameters=params6s_ast_18560.txt
>> output=ast_18560.01.radiance_atcorr
>> WARNING: Unknown aerosol model!
>> wavelength less than 0.25 micron:
>> let's take s(l)=s(0.25)
>> * ****************************** 6s version 4.2b
>> * geometrical conditions identity
>> * ASTER observation
>> * month: 6 day: 22
>> * solar zenith angle: 34.61 deg solar azimuthal angle: 38.12
>> deg *
>> * view zenith angle: 0.00 deg view azimuthal angle: 0.00
>> deg *
>> * scattering angle: 145.39 deg azimuthal angle difference: 38.12
>> deg *
>> * atmospheric model description
>> * atmospheric model identity :
>> * tropical (uh2o=4.12g/cm2,uo3=.247cm-atm)
>> * aerosols type identity :
>> * user defined aerosols model
>> * optical condition identity :
>> * visibility : -0.10 km opt. thick. 550nm : 0.0000
>> * spectral condition
>> * target type
>> * homogeneous ground
>> * constant reflectance over the spectra 0.000
>> * target elevation description
>> * ground pressure [mb] 0.00
>> * ground altitude [km] 99.990
>> * gaseous content at target level:
>> * uh2o= 0.000 g/cm2 uo3= 0.000 cm-atm
>> * plane simulation description
>> * plane pressure [mb] 0.00
>> * plane altitude absolute [km] 396884967424.000
>> * atmosphere under plane description:
>> * ozone content 0.000
>> * h2o content 0.000
>> * aerosol opt. thick. 550nm 0.000
>> * atmospheric correction activated
>> Atmospheric correction...
>> Segmentation fault: 11
>> I've tried with 7.0.2 and 6.0.4 versions, both end up in the same error.
>> If I try to run it from a python script I a bit more information:
>> grass.run_command('i.atcorr', input=ast_band,
>> elevation='srtm_xingu_3sec', parameters=fname,
>> output=ast_band+'_atcorr_6s', verbose=True)
>> WARNING: Unsupported iwave value: 809775095
>> * ASTER observation
>> * month: 6 day: 22
>> * solar zenith angle: 34.65 deg solar azimuthal angle: 38.18
>> deg *
>> deg *
>> * scattering angle: 145.35 deg azimuthal angle difference: 38.18
>> deg *
>> * Traceback (most recent call last):
>> File "<stdin>", line 1, in <module>
>> File
>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
>> line 394, in run_command
>> return handle_errors(returncode, returncode, args, kwargs)
>> File
>> line 312, in handle_errors
>> returncode=returncode)
>> File
>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/exceptions/__init__.py",
>> line 68, in __init__
>> msg = _("Module run %s %s ended with error") % (module, code)
>> TypeError: 'str' object is not callable
>> any help is appreciated
>> Carlos
>> Prof. Carlos Henrique Grohmann
>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>> - Digital Terrain Analysis | GIS | Remote Sensing -
>> http://carlosgrohmann.com
>> http://orcid.org/0000-0001-5073-5572
>> ________________
>> Can’t stop the signal.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160321/51e080d4/attachment-0001.html>
