[GRASS-user] i.atcorr returning empty raster and not respecting input parameters [WAS: i.atcorr - segfault on OSX]
Daniel Victoria daniel.victoria at gmail.com
Mon Mar 21 07:59:52 PDT 2016
Hi Carlos,
>From the manual [1], the 0-255 rescaling is default. So I believe if you
want to use some other rescaling, you have to do it manually. To be honest,
I never understood what are the best options to use in the rescale
parameter. I imagine the 0-255 is reminiscent from the 8-bit images. So
what about higher bit images. Should we use other rescaling factors?
[1]: https://grass.osgeo.org/grass71/manuals/i.atcorr.html
On Mon, Mar 21, 2016 at 11:40 AM, Carlos Grohmann <carlos.grohmann at gmail.com
> wrote:
> Thanks Daniel!
> That was really dumb of not double-checking the input parameters..
> Now another problem: the resulting image is empty! r.info returns "min =
> nan  max = nan".
> I tried with radiance and reflectance as inputs. One thing that I realized
> is that, even though I'm not setting it to rescale the output range, it's
> doing it:
>  |   Comments:
>  |    i.atcorr --overwrite --verbose -r
> input="ast_18560.01.toa_reflectanc\   |
>  |    e at lateritas" range=0,255 elevation="srtm_xingu_3sec at lateritas"
> param\   |
>  eters="/Volumes/MacintoshHD2/Dropbox/USP/projetosPesquisa/Xingu_late\   |
>  |    ritas/aster/params6s_ast_18560.txt"
> output="ast_18560.01.toa_reflect\   |
>  |    ance_atcorr_6s" rescale=0,255
> Here I didn't set neither range nor rescale (left them blank), but
> apparently the command is not respecting my choices. bug detected?
> After this I tried setting the input range and rescale options, but
> without success. Still an empty raster...
> best
> Carlos
> On Mon, Mar 21, 2016 at 8:54 AM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Carlos,
>> The aerosol model is the 4th line in the parameter file. You have set the
>> aerosol model to 15. But in the i.atcor manual, the values range from 0 to
>> 11. Could that be the problem? i.atcor issues an unknown aerosol model
>> warning and assumes you are trying to enter aerosol models by hand. Hence
>> it sets your visibility to -0.1 (ground altitude) and other parameters
>> wrong.
>> Cheers
>> Daniel
>> On Fri, Mar 18, 2016 at 4:49 PM, Carlos Grohmann <
>> carlos.grohmann at gmail.com> wrote:
>>> Hi all.
>>> I'm trying to run some atmospheric correction of ASTER images. First I
>>> calculated radiance and reflectance (with my own script, not
>>> i.aster.toar).  I've tried with radiance and reflectance as input, but both
>>> end up in a segfault.. the parameters file has this content:
>>> 10
>>> 6 22 13.99 -51.931 -3.355
>>> 1
>>> 15
>>> -0.100
>>> -1000
>>> 72
>>> and this is the call to i.atcorr and the error:
>>> (region is defined to the raster)
>>>  i.atcorr --overwrite --verbose input=ast_18560.01.radiance
>>> elevation=srtm_xingu_3sec parameters=params6s_ast_18560.txt
>>> output=ast_18560.01.radiance_atcorr
>>> WARNING: Unknown aerosol model!
>>>  wavelength  less  than  0.25  micron:
>>>  let's take s(l)=s(0.25)
>>> * ****************************** 6s version 4.2b
>>> *                        geometrical conditions identity
>>> *                        ASTER    observation
>>> *    month: 6 day: 22
>>> *    solar zenith angle:   34.61 deg  solar azimuthal angle:       38.12
>>> deg   *
>>> *    view zenith angle:     0.00 deg  view azimuthal angle:         0.00
>>> deg   *
>>> *    scattering angle:    145.39 deg  azimuthal angle difference:  38.12
>>> deg   *
>>> *                        atmospheric model description
>>> *            atmospheric model identity :
>>> *                tropical            (uh2o=4.12g/cm2,uo3=.247cm-atm)
>>> *            aerosols type identity :
>>> *                 user defined aerosols model
>>> *            optical condition identity :
>>> *                 visibility :   -0.10 km  opt. thick. 550nm :   0.0000
>>> *                        spectral condition
>>> *                        target type
>>> *            homogeneous ground
>>> *              constant reflectance over the spectra     0.000
>>> *                        target elevation description
>>> *            ground pressure  [mb]          0.00
>>> *            ground altitude  [km]       99.990
>>> *                 gaseous content at target level:
>>> *                 uh2o=    0.000 g/cm2        uo3=    0.000 cm-atm
>>> *                        plane simulation description
>>> *            plane  pressure          [mb]      0.00
>>> *            plane  altitude absolute [km] 396884967424.000
>>> *                 atmosphere under plane description:
>>> *                 ozone content                0.000
>>> *                 h2o   content                0.000
>>> *                aerosol opt. thick. 550nm     0.000
>>> *                         atmospheric correction activated
>>> Atmospheric correction...
>>> Segmentation fault: 11
>>> I've tried with 7.0.2 and 6.0.4 versions, both end up in the same error.
>>> If I try to run it from a python script I a bit more information:
>>> grass.run_command('i.atcorr', input=ast_band,
>>> elevation='srtm_xingu_3sec', parameters=fname,
>>> output=ast_band+'_atcorr_6s', verbose=True)
>>> WARNING: Unsupported iwave value: 809775095
>>> *                        ASTER    observation
>>> *    month: 6 day: 22
>>> *    solar zenith angle:   34.65 deg  solar azimuthal angle:       38.18
>>> deg   *
>>> deg   *
>>> *    scattering angle:    145.35 deg  azimuthal angle difference:  38.18
>>> deg   *
>>> *           Traceback (most recent call last):
>>>   File "<stdin>", line 1, in <module>
>>>   File
>>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
>>> line 394, in run_command
>>>     return handle_errors(returncode, returncode, args, kwargs)
>>>   File
>>> line 312, in handle_errors
>>>     returncode=returncode)
>>>   File
>>> "/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/exceptions/__init__.py",
>>> line 68, in __init__
>>>     msg = _("Module run %s %s ended with error") % (module, code)
>>> TypeError: 'str' object is not callable
>>> any help is appreciated
>>> Carlos
>>> Prof. Carlos Henrique Grohmann
>>> Institute of Energy and Environment - Univ. of São Paulo, Brazil
>>> - Digital Terrain Analysis | GIS | Remote Sensing -
>>> http://carlosgrohmann.com
>>> http://orcid.org/0000-0001-5073-5572
>>> ________________
>>> Can’t stop the signal.
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> ________________
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160321/02df2be7/attachment-0001.html>
