[GRASS-user] E-OBS climate data and TGIS in GRASS
Markus Metz markus.metz.giswork at gmail.com
Tue Mar 22 14:11:57 PDT 2016
On Sat, Mar 19, 2016 at 9:01 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Hi Veronica,
>>There is a presentation from Soeren at 2012 GEOSTAT course [0] in which he
> uses one of ECAD datasets as >example. Maybe useful?
> thanks for the hint!
>>Which particular dataset there you want to use?
> http://eca.knmi.nl/download/ensembles/download.php#datafiles
> daily mean temperature TG,
> daily minimum temperature TN
> daily maximum temperature TX
> daily precipitation sum RR
ECA&D contain some serious errors:
1. look at the spatial distribution and location of the stations used
http://eca.knmi.nl/download/ensembles/data/ensembles_tg_stations_v12.0.txt
http://eca.knmi.nl/download/ensembles/data/ensembles_tn_stations_v12.0.txt
http://eca.knmi.nl/download/ensembles/data/ensembles_tx_stations_v12.0.txt
http://eca.knmi.nl/download/ensembles/data/ensembles_rr_stations_v12.0.txt
2. calculate annual averages and check if they match your
expectations. They did not match my expectations (and those of my
group) so we decided to ditch ECA&D.
>>what are you interested in doing, if I may ask?
> I have vegetation samples across Europe, from the North to the South, from
> the West to Caucasus. as this vegetation types are sensitive to temperature
> and precipitation, such parameters may be included in ecology pattern
> analysis.
If possible, use a datasource different from ECA&D.
Markus M
> best regards
> Helmut
> View this message in context: http://osgeo-org.1560.x6.nabble.com/E-OBS-climate-data-and-TGIS-in-GRASS-tp5257384p5257393.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
