[GRASS-user] E-OBS climate data and TGIS in GRASS
Helmut Kudrnovsky
hellik at web.de
Tue Mar 22 14:18:07 PDT 2016
Markus Metz-3 wrote
> On Sat, Mar 19, 2016 at 9:01 PM, Helmut Kudrnovsky <
> hellik@
> > wrote:
>> Hi Veronica,
>>>There is a presentation from Soeren at 2012 GEOSTAT course [0] in which
he
>> uses one of ECAD datasets as >example. Maybe useful?
>> thanks for the hint!
>>>Which particular dataset there you want to use?
>> http://eca.knmi.nl/download/ensembles/download.php#datafiles
>> daily mean temperature TG,
>> daily minimum temperature TN
>> daily maximum temperature TX
>> daily precipitation sum RR
> ECA&D contain some serious errors:
> 1. look at the spatial distribution and location of the stations used
> http://eca.knmi.nl/download/ensembles/data/ensembles_tg_stations_v12.0.txt
> http://eca.knmi.nl/download/ensembles/data/ensembles_tn_stations_v12.0.txt
> http://eca.knmi.nl/download/ensembles/data/ensembles_tx_stations_v12.0.txt
> http://eca.knmi.nl/download/ensembles/data/ensembles_rr_stations_v12.0.txt
> 2. calculate annual averages and check if they match your
> expectations. They did not match my expectations (and those of my
> group) so we decided to ditch ECA&D.
>>>what are you interested in doing, if I may ask?
>> I have vegetation samples across Europe, from the North to the South,
>> from
>> the West to Caucasus. as this vegetation types are sensitive to
>> temperature
>> and precipitation, such parameters may be included in ecology pattern
>> analysis.
> If possible, use a datasource different from ECA&D
thanks for the insigth to this dataset.
do you have any recommondations for alternatives regarding Europe?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/E-OBS-climate-data-and-TGIS-in-GRASS-tp5257384p5257891.html
Sent from the Grass - Users mailing list archive at Nabble.com.
